when i drive my car after it rains, freezing water pours on my clutch foot
Old Mar 31, 2003 | 05:49 PM
xcathodex's Avatar
Default when i drive my car after it rains, freezing water pours on my clutch foot
and it SUCKS! i checked the big drain channels under the hood for obvious clogs but didn't see anything....i'm thinking i'll run a pressure washer through there this week. any suggestions or experiences from people with similar problems?
Old Mar 31, 2003 | 05:54 PM
ScottEK's Avatar
Default Re: when i drive my car after it rains, freezing water pours on my clutch foot (xcathodex)
I think I might know, I was actually going to ask about this a week ago. I was installing a replacement antenna on my rex last week. While I was running the antenna cable I notice a thick plastic tube was running down the same path as the antenna wire. My guess was that this tube was the drain tube for the sunroof. To my suprise later on while I was running cable under the dash, I noticed the same tube came to end right there. My guess is this tube is your culprit.
Old Mar 31, 2003 | 06:01 PM
bodymodgrl's Avatar
Default Re: when i drive my car after it rains, freezing water pours on my clutch foot (beta13)
This actually happened to two of my friends who both drive Hondas. In both cars it had something to do with their air conditioners.
Old Mar 31, 2003 | 06:04 PM
Hybrid Invasion's Avatar
Default Re: when i drive my car after it rains, freezing water pours on my clutch foot (bodymodgrl)
major suckage. Just check everything that drains out in that area; most of the answers are right in front of you. Don't let a simple problem stump you.
Old Mar 31, 2003 | 06:30 PM
ScottEK's Avatar
Default Re: when i drive my car after it rains, freezing water pours on my clutch foot (Hybrid Invasion)
Anyone know what tube I am talking about, it seems kind of weird that any tube would drain stop and drain into the passenger compartment.
Old Mar 31, 2003 | 06:56 PM
blah13's Avatar
I've had an a/c connection problem on my passenger side, a metal bar that held a piece of foam type stuff over a crack where the air flowed and the cold air would cause condensation and I'd get puddles on my passenger floorboard, not sure if that same part runs under the driver side dash, look around.
edit: obviously this happend rain or no rain so ex that
[Modified by blah13, 3:56 AM 4/1/2003]
Old Mar 31, 2003 | 07:01 PM
Wes d's Avatar
Default Re: when i drive my car after it rains, freezing water pours on my clutch foot (blah13)
Mine gets a load of water coming in from the air vent intake, located under the grill below winshield wiper. Same problem as you- wet foot syndrome. I haven't bothered to fix it but I have traced the leak positively to there.
Old Mar 31, 2003 | 07:42 PM
CRXTSEE's Avatar
Default Re: when i drive my car after it rains, freezing water pours on my clutch foot (Wes d)
wet foot syndrome here too.... it makes for a nice surprise when you are wearing shorts and you feel a splash around your ankle.
it hardly rains in cali so I'm not gonna chase it down
Old Mar 31, 2003 | 07:52 PM
ncrx1's Avatar
Default Re: when i drive my car after it rains, freezing water pours on my clutch foot (CRXTSEE)
check the grommet that seals the hood cable release cable.. i had a problem with that...
also test the sunroof drain tube that runs down the a pillar.
NL826
Feb 13, 2010 07:35 PM
viciousef9
Feb 27, 2008 06:27 PM
96CXhatch
18
Oct 27, 2005 08:54 PM
JDMike_DB8R
Jun 8, 2005 10:28 AM
tylerdurden
12
Oct 24, 2002 08:56 AM
