zc swap problem
i finish the zc swap yeasterday i drove the car to work this morning and
it ran very good but, whe i drove it up after work the rpm wont pass 3000rpm it feels like cut off
lower than 3000rpm it runs good
help also is trowing code 9
the search doesnt work
your timing is off...put the engine at TDC and see what your cams are at...probably off a tooth or two...dont drive it, untill you fix it...
Ugh, code 9 is horrible to fix, my ZC swap ate up two seperate distributors. Be positive your wiring from distributor to car harness is all matched color for color.
CrX-To-Tha-Max-v2.0
Feb 26, 2005 02:01 PM
