crx interior
Old Mar 31, 2003 | 05:22 PM
dowd's Avatar
Default crx interior
will interior panels and pieces such as door panels and dash from
a 88 crx fit into a 90 crx. thanks
Old Mar 31, 2003 | 05:52 PM
hardcorepreston's Avatar
Default Re: crx interior (dowd)
here are some differences im not to sure about the fixment tho
i got the info from crxsi.com
90-91 have a round instrument gauge cover while the 88-89 one is more squarish.
88's have pillar mounted seatbelts,90-91 have door mounted belts, 89 si's and dx's have door mounted belts, 89 hf's have pillar mounted belts.
Models with door mounted belts have a wider pillar at the end of the door to accomodate the belt mount, this also means that the glass is and inch or so shorter.
90-91's have a red seatbelt warning light built into the dome light.
88 has a pocket at the bottom of the drivers door.
Old Mar 31, 2003 | 07:01 PM
TheBestCRX's Avatar
Default Re: crx interior (hardcorepreston)
hardcorepreston is correct on all that info.
you can probably put the 88 dash in a 90-91 but the door panels will be a problem because 90-91 rexes have door seatbelts. so unless you want to relocate the seatbelt than you need 90-91 panels.
jdmb20boi
Jul 10, 2008 06:27 PM
wfocrx
May 9, 2006 12:21 AM
joeyblow
Oct 2, 2005 02:41 PM
B2FiNiTY
20
Dec 13, 2003 09:46 AM
^Sammy]!.
Jul 28, 2002 08:02 AM
