Need S-AFC wiring instructions for 90 Integra (pr4).. can't find anywhere!
I'm lost with the search on the archive disabled.. i'm looking for the diagram so I can hook up the S-AFC I just got in my B18a integra.. i'm sure someone knows where to find it.. TIA!
This is for VAFC:
Red Wire - Ignition Power
Orange Wire - Ignition Power
Green Wire - Engine RPM (ICM) on hondas it is yellow/green on the ECM
Gray Wire - Throttle Sensor
Black Wire - Ground
Brown Wire - Ground (Tie the Brown wire into the same ECU ground used above, only closer to the ECU, I don't know why, but APEXI says so)
Blue - VTM Signal (VTEC Oil Pressure Sensor) Tie into ECU, leave wire going to engine dangling
Pink - To VTEC Solenoid
Purple - To ECU VTEC Solenoid Wire
White - to MAP Sensor
Yellow - to MAP sensor wire on ECU
Black Wire - Ground
S-AFC is the same, less the two VTEC wires.
I have pics of where they go on the ECU plugs, can digicam + email if needed; web gallery is down atm.
