I need a SOHC wizard to help!!!
Old Mar 31, 2003 | 03:43 PM
Irishweird00's Avatar
Banned
Default I need a SOHC wizard to help!!!
Just got this a couple days ago, And got all the parts i need to put it on my y7, Just need to know if im missing anything, and if i can actually put this on my 97 dx... its a 00 y8 manifold.
If you notice in the last pic, the gasket is for a 96-98 y8 manifold, and there is another one that i have, that is for the 99-00... need to know if i can use this manifold.
Old Mar 31, 2003 | 03:47 PM
Ricey McRicerton's Avatar
Default Re: I need a SOHC wizard to help!!! (Irishweird00)
Yes itll fit....theres a reall good site but Im at work and dont have access to it right now..somebody help him out *even though a search would have told you*
Old Mar 31, 2003 | 03:48 PM
2000CX's Avatar
geez...where did you get such a clean manifold from? i tried to get a y8 and ended up with a z6...now that is just a paper weight
oh, it looks complete to me...the only thing i don't see is the throttle cable from an EX.
EDIT: heres the swap page http://www.makuragi.s5.com/civic_99/Y8maniswap/
[Modified by 2000CX, 7:49 PM 3/31/2003]
Old Mar 31, 2003 | 03:52 PM
Banned
Default Re: I need a SOHC wizard to help!!! (2000CX)
Yeah thank, I already got that printed out, if you look at both manifolds... they are different. Thats all i really need to know...
Edit: oh yeah, i got it off ebay 20K on it
[Modified by Irishweird00, 7:54 PM 3/31/2003]
Old Mar 31, 2003 | 04:04 PM
Banned
Someone told me to plug the holes that go into the fuel injectors, at the top of the manifold with RTV sealant, and then i can use it...
Old Mar 31, 2003 | 04:39 PM
Marauder's Avatar
Yes, plug the four small holes into the injectors, and the one in the middle, top part of the flange.
Old Mar 31, 2003 | 04:41 PM
Banned
Default Re: I need a SOHC wizard to help!!! (Marauder)
thanks alot.
Old Mar 31, 2003 | 05:37 PM
98slvrcx's Avatar
that looks a bit different then a 96-98 IM . No plugging..... was required on the 96-98 except for the cruise control. You can actually use ur y7 TB but swith the TB disk or modifiy it and flip it 180deg (like I did) to make it work .
Old Mar 31, 2003 | 05:38 PM
kommon_sense's Avatar
yep, looks like all you need is the throttle cable. Have you considered throwing a b-series TB on while you are at it?
Old Mar 31, 2003 | 05:40 PM
Banned
Default Re: I need a SOHC wizard to help!!! (kommon_sense)
Yup thought about it, but i gotta get it bored out dont I?? i thought i can use my throttle cable... why do i need a ex one?
2000CX's Avatar
hmmm...a bseries tb will work on this setup? how about sensors? i thought the y7 tb was a direct swap with the y8...so modifications DO need to be made?
Old Mar 31, 2003 | 05:48 PM
Marauder's Avatar
Keep the D-series TB unless there are a lot of mods already on the Y7. If you have a manual trans Y7 with the same idle air motor as this Y8 (two wire) then your Y7 harness should connect right up to this one.
Old Mar 31, 2003 | 05:57 PM
2000CX's Avatar
how does everyone feel about also upgrading the distributor to the y8? worth it or not...
Old Mar 31, 2003 | 06:41 PM
Turbo Powa's Avatar
Are you using the Y8 tb? You do know for the IAC valve there different form the non vtec. I just did a mini me swap a few months back. All you need to do is swap the Y7 and Y8 Tb. Use some kind of gasket and cover the Y8 IAC valve with a gasket and all you need to do is clip everything back on. As for the throttle cable. I just swaped the thingy where the cable hooks up. Swap the Y7 to the Y8 for the throttle cable.
Old Mar 31, 2003 | 06:43 PM
Ya@inlinePRO's Avatar
Default Re: I need a SOHC wizard to help!!! (Panda EK)
sup dude, you get your mini me workin fine now?
Old Mar 31, 2003 | 06:56 PM
Turbo Powa's Avatar
Default Re: I need a SOHC wizard to help!!! (kwik2nec)
its all set up except the vtec. I still cant figure out how to install the rpm activated switch. Might be getting a fields vtec pretty soon.
Old Mar 31, 2003 | 07:00 PM
Banned
thanks guys, now all i have to do is figure out if its from a manual or a automatic...!!!! im so retarded i forgot to ask!
Old Mar 31, 2003 | 08:21 PM
sirdalink's Avatar
A friend of mine bought one from ebay and it turned out that it was from an automatic. Sold is back on ebay and made an extra $20 off of it.
Old Mar 31, 2003 | 08:35 PM
drunkenbabyseal's Avatar
what kind of hp and tq gains can be made by swapping the mani.?
Old Mar 31, 2003 | 08:43 PM
That is from a manual because you have the iacv mounted on the back of the IM.
Also, yes, you would need to bore the IM out to use a b-series TB. Nothing an afternoon with a dremel and some sandpaper couldn't fix. I've got a spare y8 IM w/gsr TB sitting on the table. I'll try to remember to take pics of the process when I get around to porting it.
Old Mar 31, 2003 | 08:45 PM
Quad-Damag's Avatar
Default Re: I need a SOHC wizard to help!!! (drunkenbabyseal)
they dx tb, will fit, but won't work right, u need to change how the tb works, use a 92-95 ex tb spring, or a 96-00 tb spring, and move it so it opens the tb, so the cable can fit in it, ur going to have to d hook the dx tb, and move it and make it custom mounted to your fuel rail, look how i have mine.
This is a d16y7
I use the thing that holds it on the right side, and blot it with part of the fuel regulator. It holds nice, and the tb works.
Old Apr 1, 2003 | 05:57 AM
Banned
Default Re: I need a SOHC wizard to help!!! (Quad-Damge)
Thanks, while im at it, what are the torque specs for the manifold to the head???
I need to know just in case i don't gave the spare change to pick up a helms for myself.
Old Apr 1, 2003 | 07:50 AM
Marauder's Avatar
I think there is a torque....but do you think you can get a torque wrench on all of those?? Its not easy....I don't use a torque wrench, although since I have been wrenching for about 10 years now, I can feel it, like calibrated hands.
If you want the spec....its: 23 N-m or 17 ft-lbs
Old Apr 1, 2003 | 10:06 AM
Quad-Damag's Avatar
You should get some hp out of it, around 6 to 10hp, mine pulls hard around 45mph for a automatic civic.
Old Apr 1, 2003 | 10:59 AM
Banned
Thanks for all the help I prolly would have never done this if i didnt get on H-T !!! Once I get my tach, and a cheap *** intake, ill put this puppy on..... hopeing for the best, preparing for the worst
Iloveyourhonda92
Mar 25, 2010 01:39 PM
immajackuup
Apr 19, 2008 04:49 PM
jdmtuner_00
Apr 2, 2008 01:14 PM
mr. carpenter
Apr 20, 2005 01:58 PM
Irishweird00
Mar 27, 2003 08:45 AM
