stupid question? not sure.. help me out. clutch/flywheel for b18a compatible with vtec head.
Old Mar 31, 2003 | 03:35 PM
djay86's Avatar
Default stupid question? not sure.. help me out. clutch/flywheel for b18a compatible with vtec head.
Got a stock b18a in a g2 integra. Adventually going LS VTEC. Wanted to upgrade the clutch/flywheel. If I upgrade, will it still work once i get a different head on there. I'm pretty sure yea, but arent b16 and b18 cable engines, dont they have different clutches? Ahh sorry if this seems like a stupid question. Just seemed a little confused and wanted to clear it. Thanks
-djay
Old Mar 31, 2003 | 04:42 PM
joe_bocc's Avatar
Default Re: stupid question? not sure.. help me out. clutch/flywheel for b18a compatible with vtec head. (dj
Well since you will be keeping the B18A block, which where the clutch actually connects to the engine, I think there should have no problems.
Old Mar 31, 2003 | 05:57 PM
Kataku2K3's Avatar
When you do your LSVTEC swap your tranny out too... The only problem that could arise would be if you decided to run a hydro tranny conversion... Even if you decided to do that all you would have to swap would be the clutch disk... I really doubt you were planning on this but if you go with a Y1 or YS1 (92-93 B17A) then you'll be just fine... OTHERWISE THERE ARE NO PROBLEMS!!!
impreziv
Jul 20, 2008 10:53 AM
dividedas1
Apr 4, 2008 10:43 AM
Origin
Sep 11, 2005 08:00 PM
BigIslandBoi
Apr 29, 2004 10:42 AM
giooooo
Oct 3, 2002 02:36 PM
