What ECU is used for the D15B 3 stage VTEC?
Old Mar 31, 2003 | 03:06 PM
loudsubz's Avatar
Default What ECU is used for the D15B 3 stage VTEC?
I have been looking all over but havnt found a clear answer to this.
Old Mar 31, 2003 | 05:18 PM
civicmandx94's Avatar
Default Re: What ECU is used for the D15B 3 stage VTEC? (loudsubz)
3 stage vtec? What are you talking about. A p06 is for the D15B7 but it doesn't run vtec. Maybe try a p28, I have heard that they can run sohc engines. A little more info on the engine would be great. Maybe then I can help you a little more. Thanks and God bless!
Old Mar 31, 2003 | 05:29 PM
Eee Pee's Avatar
Default Re: What ECU is used for the D15B 3 stage VTEC? (civicmandx94)
If it's the vx/z6 head combo/d15b jdm motor, I'd believe it would be the p28.
This is what runs the Z6.
If it is the 3 stage, (I think) like the HX {Ihatethat}, I'm sorry I don't know.
If that was any help.
D motors rule.
Old Mar 31, 2003 | 06:05 PM
del_sol's Avatar
Default Re: What ECU is used for the D15B 3 stage VTEC? (Eee Pee)
all i kno is i swapped out my blown z6 for a jdm d15b, and i kept my chipped ECU, and have no problems...
Old Mar 31, 2003 | 06:54 PM
loudsubz's Avatar
Default Re: What ECU is used for the D15B 3 stage VTEC? (del_sol)
sorry guys for not providing anymore info but heres a good start/read.
http://asia.vtec.net/article/d15b/
Old Mar 31, 2003 | 07:03 PM
JunelSiR's Avatar
d15b is better then a d16z6 its the best sohc engine 130hp <---
[Modified by JunelSiR, 8:04 PM 3/31/2003]
Old Mar 31, 2003 | 07:12 PM
YumVTEC's Avatar
Default Re: What ECU is used for the D15B 3 stage VTEC? (JunelSiR)
i wonder what a d15b vtec head on a d16z6 block would run like...
Old Mar 31, 2003 | 07:15 PM
Eee Pee's Avatar
Default Re: What ECU is used for the D15B 3 stage VTEC? (YumVTEC)
A Z6, seeing how a d15b is a VX d15 with a Z6 head.
Old Mar 31, 2003 | 07:38 PM
loudsubz's Avatar
since the d15b goes through a couple diff stages woulnd't it require a diff ecu than the P28 etc, or just the same single wire hookup and the 2 vtec solenoids do the work after?
My friend bought this engine but im checking to see if he has the right ecu.
Old Mar 31, 2003 | 10:41 PM
X2BOARD's Avatar
I don't know about that... the d15b head is not the same as the z6 head, as in the thread's title, the d15b has a 3 stage vtec incorporated into the valvetrain.
I am not sure if the p28 would work... but I guess I will find out... just bolted a d15b head onto a friend's Y8 block... but the car won't start... might just be the ghetto rig distributor... but maybe not.
I figured the vtec was just controlled by the solenoid alone, but maybe the ecu delivers diff voltages at the diff rpm. The fuel map DOES lean the mixture out during the 2nd vtec stage.
BTW, I disagree that the d15b is better than the d16z6... for gas mileage, yeah, but what about the tq curve ? The 3 stage vtec might make about 130 hp, but lets face it... the d15 was designed with fuel economy in mind more than performance.
X2
Old Apr 1, 2003 | 07:43 PM
loudsubz's Avatar
Default Re: What ECU is used for the D15B 3 stage VTEC? (X2BOARD)
any other insights?
thanks.
Old Apr 1, 2003 | 09:49 PM
X2BOARD's Avatar
Well, I got the car to start with the right distributor housing. (Timing was waaay off before) This particular head is a d15b, but not from the EK3 which has the 3 stage vtec (as far as I can tell).
The combo is a Y8 block with a d15b head and Y8 Intake manifold. Running the stock computer for the Y8.
The car runs fine, smooth and vtec engages smoothly, but not very powerful. I still have the timing a tiny bit retarded for the first day or two (fresh head). After that, I will advance it and see/post how the performance goes.
There is a small header leak, so that will be fixed tomorrow as well.
As far as the actual 3 stage vtec version, I figure the dual solenoids would handle that duty....
X2
Old Apr 1, 2003 | 11:02 PM
South Bay Surfer's Avatar
From: South Bay, Torrance/Carson, CA, United States
i got this motor and i try my best to hear or feel vtec, but i'm not sure if its working because the motor feels kinda week. i thought because it had 130hp it would be a world of difference between it and what i originally had in my car the d15b7 which is 102hp.
Old Apr 2, 2003 | 07:55 AM
X2BOARD's Avatar
Default Re: What ECU is used for the D15B 3 stage VTEC? (iluvjasmine)
Well what ECU are you using ?
X2
Old Apr 2, 2003 | 08:13 AM
crx8psi's Avatar
The right ecu is the jdm P08 I dont think they made a usdm version of the ecu. I remember a while back somebody on this site had a few for sale but I dont remember who.
Old Apr 2, 2003 | 10:41 PM
Default Re: What ECU is used for the D15B 3 stage VTEC? (b16a88hatch)
chipped p28
Old Apr 3, 2003 | 10:41 PM
iii
Old Apr 6, 2003 | 06:57 PM
kikiboi's Avatar
you dont need a chipped p28, a regular p28 will work as well. i know a couple people on honda tech that have this engine and have used just the p28
Old Apr 29, 2004 | 03:56 AM
vanness33's Avatar
Default Re: What ECU is used for the D15B 3 stage VTEC? (kikiboi)
the right ecu is a p2j
97Ej6mike
Jan 7, 2007 02:13 PM
craigie
Jan 16, 2006 01:33 PM
DasaEJ1
14
Jan 16, 2005 12:27 PM
an2ny888
23
Apr 24, 2004 05:57 AM
1990hondaHF
Jul 25, 2003 09:02 PM
