I'm redo-ing my headliner, should I dynamat?
Hello
I'm getting my headliner redone on my 95 accord coupe (which came w/ an aftermarket moonroof)
Should I spend spend the time/money/weight of putting dynamat in there myself as well? I hear some vibrations so I thought maybe this may be a good idea? Would i be adding too much weight?
Thanks
Thanks
negative dude. how much noise comes from up? all the noise comes from the engine and the tires. concentrate your dynamat down low. If you're worried about shakes and rattles then spot check and use some expanding foam.
besides you'd raising the car's center of gravity. a larger enough change to feel? probably not but it's the theory that counts!
el_espiritu
Jan 26, 2013 02:53 PM
Mungo
Nov 22, 2004 12:37 PM
