Which clutch cable for CRX si with b16a swap?
I think hasport recommends the 90-93 teg one, but I have always been able to make the factory crx one work.
just a bit on the tight side.
jeff
jeff
before i did my swap, i was told that the stock Si cable would work fine. however, in the middle of my swap, i found this to be untrue. i had to make a special trip to acura and it wasted a lot of time. in the end, the integra one worked fine. it was just a hassle to not have the correct info at the start of the swap. i would recommend buying it before your swap and if you dont use it, just return it.
should be able to get the stock one to work... but if not get the teg one.
jdmdude
Jun 13, 2005 07:33 AM
speedjunkeez
Aug 15, 2001 10:18 PM
