are zc's good to go????
im ordering a zc motor for my 91 hatchback in about 3 weeks, does anybody know if they are ready to go in or do they need to be re-built? i always hear about people re-building them--is it becuase they are bad when they get them or just cause they put some use into em'? i planned on getting it from Nippon-Motors Inc., everyone i talked to said that they were good, motors are nice! any info. would help-thanks!
Most ZC engines you will get from a supplier such as Nippon-Motors is low mileage and can be installed without a re-ring. It has been my experience that these engines will operate with little or no oil use for many miles. I have installed or sold about 10 ZC's in the past year and have had to warranty only one for oil use.
It will be necessary to install a new t/belt, crank seal, cam seals, water pump. A valve adjustment with new V/C gasket and grommetts, rear main seal, clutch, NGK spark plugs, wire set, dist/rotor, thermostat and other basic service tems.
The oil pan will proably be bent and will need to be replaced with the one from your old engine. A new O/P gasket will be needed. Check the O/Pump screen while you have the pan off. Apply HondaBond HT to the lps and corners of the O/Pan gasket where it meets the Oil/pump and rear main holder.(Be sure to check the oil pan drain plug boss for damage).
God Bless,
Semper FI,
Angelo.
God Bless,
Semper FI,
Angelo.
Theoriginaldead
Mar 10, 2013 12:02 AM
JDMefHATCH7
Nov 29, 2009 01:29 PM
Xander teh Grate!
Jul 18, 2006 11:22 AM
