JDM HID conversion wiring???
Old Mar 31, 2003 | 11:24 AM
aaj23's Avatar
Default JDM HID conversion wiring???
Has anyone here done the wiring for the HID headlights that come with the Jap spec conversion. I just got the conversion and was gonna have my body shop do it all, but wanted to find out how the heck you wire it up????? I have an 01' ITR if that helps at all....
Thanks,
Aj
Old Mar 31, 2003 | 02:30 PM
skafia's Avatar
25 Year Member
Default Re: JDM HID conversion wiring??? (aaj23)
It should be fairly simple right?
Your OEM green wire is positive, and your black wire is negative.
Hook it to positive and negative on your ballast and there you go!
I'm just guessing.
Old Mar 31, 2003 | 05:58 PM
junk yard sol's Avatar
you take a 9v battery and you put black from the headlight on negative then touch each wire to the positive and when it lights up you know that the wire you have on the 9v battery is for that particular light also the hid will only flicker with a 9v battery so dont be worried. then once you figure out wich wire is for what light you take the stock wires and hook them up...
Old Mar 31, 2003 | 08:17 PM
aaj23's Avatar
Yeah, I can figure out which wire is which, that's not really the problem, it's more the fact that I now have an extra light to contend with. I looked into getting the JDM fog light switch for the yellow city light, but no one seems to be able to get the harness for it.
I was actually hoping someone knew where to get a harness clip for the OEM HIDs, someone told me that an older prelude uses the same harness, though that sounds a little odd.
Any way, if anyone knows for sure, let me know...
Later,
Aj
Old Mar 31, 2003 | 08:22 PM
Mike M's Avatar
Founding Member
Default Re: JDM HID conversion wiring??? (JDMDC2ITR)
Or do it the right way with either a Volt Meter (So you don't burn anything out) or Get a Helms.
Old Mar 31, 2003 | 09:07 PM
:jdmshmaydm:'s Avatar
Default Re: JDM HID conversion wiring??? (Mike M)
So to wire the JDM HID's to our cars we need to splice the wires? (USDM)
Old Mar 31, 2003 | 09:29 PM
2fknlo's Avatar
Default Re: JDM HID conversion wiring??? (Gatecrasher19AF)
Is it possible to use the standard lights (non HID)
for this conversion i have a conversion kit with just the front lights
Can i power the lights with the standard loom?
Old Mar 31, 2003 | 09:31 PM
Default Re: JDM HID conversion wiring??? (2fknlo)
The non-HID front end will still utilize your OEM 9006 connecter. So you will be able to use any setup you have now for 9006, with the JDM non-HID front.
Old Mar 31, 2003 | 09:36 PM
ScaleExtric's Avatar
I am currently working on a "How-to Do it yourself wiring " page on the Jdm integra type R hid setup. I personally dont believe in sloppy wiring jobs on my car...so this page will show you how to do a clean setup. Here are some of the pics of my JDM OEM HID headlights installation. I have since put the factory plastic covering over the harness for the even more "stock" look.
[Modified by ScaleExtric, 6:37 AM 4/1/2003]
Old Mar 31, 2003 | 09:41 PM
Danger's Avatar
Default Re: JDM HID conversion wiring??? (ScaleExtric)
i just wired up some OEM HID headlights today . not that hard to do , just hard to explain it
Old Mar 31, 2003 | 09:55 PM
Mike M's Avatar
Founding Member
Same as the NON HID wiring except you take the Ground from the Low Beam and connect it with the High Beams ground both to the JDM Headlight, and you Take the (+) Low beam wire and connect it to the white wire on the Headlight plug.
The Wiring has been covered MANY times.
Old Mar 31, 2003 | 10:00 PM
Trinitron
Guest
Posts: n/a
Nice setup
[Modified by Trinitron, 11:00 PM 3/31/2003]
Old Mar 31, 2003 | 10:01 PM
well..I think with the how to page and some "perty" step by step pics...will help the people that need to see pics of what wires we are talking about...and if the wiring has been covered so many times...sorry Imma newbie and didnt know that...Just trying to help someone out with his question.
[Modified by ScaleExtric, 7:02 AM 4/1/2003]
Old Mar 31, 2003 | 10:03 PM
Mike M's Avatar
Founding Member
Just letting you know.
Old Apr 1, 2003 | 11:44 AM
aaj23's Avatar
Yeah, pics and a step by step would be much appreciated....
I've wired up many things before, I would just preffer to do this right the first time, rather than having to fiddle with it. Thanks for your help guys...
Later,
Aj
codenamezero
Audio / Security / Video
Jul 26, 2007 06:34 PM
honda_andy
Jan 22, 2006 12:11 PM
xoutlawz00x
Oct 29, 2005 05:11 PM
specie
Jan 23, 2005 11:46 AM
Kimo
May 16, 2004 04:43 PM
