... crx swap... which engines are direct bolt-ins...
Old Mar 30, 2003 | 06:54 PM
1.8T_EG's Avatar
Default ... crx swap... which engines are direct bolt-ins...
(( i wish archive searching was still enabled ))
... anyways, i was wondering which engines are a direct bolt-in swap into an 89 crx dx... i know that i have to do dpfi->mpfi, so thats a given... i have heard the jdm d15b vtec is a direct swap, any truth?... i have also been told that the 90-91 b18a from an integra is also a direct swap, true?... any others?... lemme know... thanks...
Old Mar 30, 2003 | 07:02 PM
drjondurst's Avatar
Default Re: ... crx swap... which engines are direct bolt-ins... (1.8T_EG)
The only one that I can say for a fact (cuz I just did it myself) is the DOHC ZC.. arent all d-series direct bolt in?
Old Mar 30, 2003 | 07:17 PM
crx(gator)'s Avatar
Default Re: ... crx swap... which engines are direct bolt-ins... (drjondurst)
almost all d-series are bolt in...no d16a1 in a 2nd gen crx, but 88-00 are bolt in, except wiring changes...
Old Mar 30, 2003 | 07:48 PM
MrTodd's Avatar
Default Re: ... crx swap... which engines are direct bolt-ins... (crxgator)
92+ D-series tranny's do not bolt in... Also, any 92+ d-series motor will need the 88-91 Drivers side Motor mount to fit properly. Other than this, and wiring changes you are good to go.
Old Mar 30, 2003 | 07:52 PM
crx(gator)'s Avatar
Default Re: ... crx swap... which engines are direct bolt-ins... (MrTodd)
i didnt say anything about trannies, he was asking for engines...you can fit a hydro tranny in there if you really wanted to...but hydro is for pansies...
Old Mar 30, 2003 | 08:13 PM
1990hondaHF's Avatar
I'd say the easiest would be the DOHC ZC. Very cheap and quite fast IMHO. You don't have to $#%$ around with motor mounts and trannys just plop it in! I get 30+ MPG in the city and can keep up with GT Mustangs.
daigo
Aug 7, 2009 06:56 AM
91DroppedHatch
18
Jan 19, 2005 01:53 PM
1.8T_EG
Jan 18, 2003 08:56 PM
85crx
Sep 22, 2002 07:40 PM
