went to the track today-new best
hey,finally went to the track for the first time today since the new clutch.it was bad cold and actually snowed just a bit.the track was not prepped well so the car spun like mad.i went 11.85 @ 128 mph.the car has about 3psi more left in it.i did not run anymore because the wastegate feed pipe broke and it would not make anymore boost.that was 8mph more and proved my theory that the clutch had been slipping all along.over all,i am very happy.with a well prepped track and some more tuning,it should be able to turn some low 11's @ 130+mph.
i was running an act heavy duty pressure plate and a street disc.i thought it was an xtreme pressure plate(that's what i bought).i changed to a six puck disc and it still didn't work.now i have an extreme pressure plate and a six puck disc.
it has golden eagle sleeves,je 9.0:1 pistons, & crower rods.as far as slicks go, yes,that was on M&H 24x9.5x15 on bogart wheels.
I have a Twin Disk Clutchmaster for sale, brand new $950...lemme know. It's the sintered Iron version that Jason Hunt is using...
Suprdave
Suprdave
i was runnning about 25 psi.
i am running a custom manifold that i made.the pipe is not on the manifold though.it comes off of the downpipe flange.it is braced very well and has broken the weld on the brace twice.i am going to have to do something a little different now.
what manifold were you running???
you got any picvs of the car with the slikcs on ? i wann check em out , im prob runnig thme too , but wanna see how they fit 1st.
great times man
i hope to be there real soon
great times man
yeah you should hit low 11's. are you still running the same ign map that you sent me?
Can you describe your launch technique... rpm drop v. slip, etc???
awesome man, you running stock axles? I am afraid i'm gonna break my stock ones with my CM stage 5 when i run slicks. What kind of 60 foot times are you getting with the 2 step and slicks?
