need answer right now - battery ground cable
Old Mar 30, 2003 | 05:02 PM
drjondurst's Avatar
Default need answer right now - battery ground cable
Where does the negative cable on the battery ground to? Last thing for me to do before the swap is done!!!
Old Mar 30, 2003 | 05:03 PM
MADEINIRAQ's Avatar
Default Re: need answer right now - battery ground cable (drjondurst)
goes to the chassis and then to the clutch cable bracket on the trans.
Old Mar 30, 2003 | 05:04 PM
drjondurst's Avatar
Default Re: need answer right now - battery ground cable (madeiniraq)
thx so much for the quick reply.. clutch able bracket.
Old Mar 30, 2003 | 05:05 PM
FourthGenHatch's Avatar
Yup, heres a picture of mine...
A stock car would have the connection to the terminal before the part where it connects to the body.
Old Mar 30, 2003 | 06:58 PM
kranked91dx's Avatar
Default Re: need answer right now - battery ground cable (FourthGenHatch)
Really, any mounting point on the tranny core is good, as long as you make a good contact between the batt and the engine, there is no trouble with it.
Kranked.
Old Mar 30, 2003 | 07:09 PM
drjondurst's Avatar
Default Re: need answer right now - battery ground cable (kranked91dx)
Thanks guys, I got it all hooked up, appreciate the pic too.
Old Mar 30, 2003 | 07:16 PM
crx(gator)'s Avatar
your suppose to also have the battery termnial cable go to the point on the body from where the tranny cable goes too...like in your pic...
DrDenby
Honda Civic (2001 - 2005)
Jul 6, 2015 07:13 AM
MarkM01
Apr 25, 2011 05:02 AM
dgerej2
Sep 9, 2009 07:31 PM
crxaddikt
Dec 16, 2002 03:25 PM
