When do most big cams peak?
Dynoed my car and it peaked between 8900 and 9000. This is on a stock bottom end b18c1. I was suprised it pulled that high. I would post a sheet, but I need the software. The final #'s were 176hp and 121tq. A friend just dynoed his JDM R motor with Spec b's and peaked at 8800. His final #'s were 188hp and 126 tq.
It also depends on the head, with a stock head it is like steve said usually right above 9000 but if you have some headwork done (not just a P&P) then the peak moves up higher
That is rediculously high for peak HP y'all!!! Damn, if you make 17X @ 8.8K, what do you make at 7.5K? 120? (j/k). Does the power dy off fast after peak? If not, 10K here you come. -C
Well it is a stock bottom end, so I was not too willing to push it any further, Besides, the ecu cuts out at 9200. I need some more compression!
egvtec
20
Aug 14, 2005 08:02 AM
