Need help with intake...tried search but it was disabled!!!!
Honda-Tech Double Platinum Member
Well i tried to do a search but the archive searching is disabled
HT has the shittiest search engine EVER. Anyway...back to my question. I have a 92 b18a in my crx and i was wondering what intake i should use? Ive got the one that i used for the dx and it fits...but the diameter of the intak is SMALLER than the freaking TB. So i need a bigger intake that will work with my battry in its stock location. I heard that the 99-00 Si intakes will work..but will they work with the battery in the stock location? If that wont work then are there any crx si intakes that are 3 inches or so? I think that the one for my dx was 2 1/4 or 2 1/2. Its just pissing me off that i have a restrictive aftermarket intake on it. Thanks
Sean
HT has the shittiest search engine EVER. Anyway...back to my question. I have a 92 b18a in my crx and i was wondering what intake i should use? Ive got the one that i used for the dx and it fits...but the diameter of the intak is SMALLER than the freaking TB. So i need a bigger intake that will work with my battry in its stock location. I heard that the 99-00 Si intakes will work..but will they work with the battery in the stock location? If that wont work then are there any crx si intakes that are 3 inches or so? I think that the one for my dx was 2 1/4 or 2 1/2. Its just pissing me off that i have a restrictive aftermarket intake on it. ThanksSean
No none for the crx's are 3 inches. And your gonna have to relocate your battery unless you get a smaller batter. By the way the search engine worked for me.
https://honda-tech.com/zerothread?id=458370
Use one for a 90-91 integra (AEM), it should fit perfectly...or you can always move your battery forward a bit (maybe 2 inches) for more room. Simply drill new holes for the battery tray and you should be good to go.
C M S
Jun 10, 2004 12:03 PM
Kasper.
16
May 17, 2002 10:25 AM
