squeaking coming from steering column...help
when i turn my steering wheel, it sqeaks like an SOB... anyone have any ideas how to fix it or wut it might be?
Had this same problem once when it got cold outside... SQEEEEEEK everytime I turn the wheel... Sounds like something rubbing cuase it goes away when it is warm... Heat expands
I had a busted boot on the shaft, and I think water got in there one time when it was raining. It's squeaked ever since. I replaced the boot and now it only squeaks if it hasn't been turned in a while.
) so I guess that proves your theory wrong. we had 80 degree weather this weekend. However it probably IS the change in temp? We will see when and if it gets colder out.
Is it coming from right behind the steering wheel? You might need to put somemore grease on that bad boy where the hub goes in.
ReVeNgEd-SoN
Jun 5, 2010 11:16 PM
