Removed power steering belt....
Old Mar 30, 2003 | 01:41 PM
ludedudesi's Avatar
Default Removed power steering belt....
Ok i did this last night and i felt a nice increase in low end power. it is wayyy harder to turn but i can manage. has anyone else done this and did you feel any power from it??
Old Mar 30, 2003 | 04:02 PM
rjr162's Avatar
Default Re: Removed power steering belt.... (ludedudesi)
i did, and I didn't feel crap. Not to mention it dawned on me it's *really* hard to turn, *even while you're moving*. That isn't right. You can't remove just the belt. When you turn the wheel, you'll be turning the manual rack and pinion, which is going to try to push against the hydrolic called the power steering. It's not going to let you do this. What you'll end up doing is just ware out the rack and pinion alot faster. If you want to remove it you'll have to loop the power steering lines out of the rack together.. otherwise the valve that the power steering pump goes into is going to block all the flow, causing you to also put alot of presure on your lines
Old Mar 30, 2003 | 04:05 PM
rjr162's Avatar
btw> i've seen dyno's of this done before and after... it gained something like 2 hp across the board... if you're looking for every ounce of power, it helps, but if you want to auto-cross or something, it's not worth it at all
Old Mar 30, 2003 | 04:09 PM
ludedudesi's Avatar
Default Re: Removed power steering belt.... (rjr162)
Ive heard just remove the pump altogether and save 12 lbs. plus your not fighting the system which makes it easier. and 2 hp is worth it 2 me. i dont autocross so im cool with the stiff steering. it doesnt bother me at all. i dunno how to remove all the stuff though.
Old Mar 30, 2003 | 04:32 PM
Honda318dx's Avatar
Still have PS in the racecar, preludes are to heavy to have w/ out
Old Mar 30, 2003 | 04:52 PM
rjr162's Avatar
get a helms manual.. it has a really nice "brake down" pic of what connects where. It will help alot
Old Mar 30, 2003 | 06:54 PM
TXDelSol's Avatar
i have a helms but i never use it.
UgandaHonda
May 25, 2011 10:41 PM
deemy72
Mar 27, 2009 08:46 AM
wdissident
Mar 19, 2009 02:05 PM
Turbo Powa
24
Feb 15, 2003 06:37 PM
Comtechgsr2000s
Dec 2, 2001 05:52 PM
