ecu chip VS vafc
Old Mar 30, 2003 | 01:29 PM
yaya's Avatar
Default ecu chip VS vafc
this question just popped in my head
- why would someone chip their ecu AND get a vafc?
- could a VAFC alone do the same essential job as a reprogrammed ecu?
as far as fuel and vtec i mean
Old Mar 30, 2003 | 02:34 PM
delslow94's Avatar
Default Re: ecu chip VS vafc (yaya)
change rev limit, speed limiter, timing curve...those are the basics why i changed mine. then you can fine tune with the vafc
Old Mar 30, 2003 | 02:56 PM
MikeSarr_GSR's Avatar
Default Re: ecu chip VS vafc (delslow94)
delslow94 is on the money.
also, chipping is relatively complex and not something
you can do every day unless you have all the tools and
the knowledge to do so as well as a dyno to play with.
as you get other mods, the more agressive timing curve
of the ECU remapping depending on the program will
allow you to get more out of basic bolt ons with less
tuning. However, if you want that extra oomph, the
VAFC will help with that and allow for microtuning,
however NO adjustments to timing map which is where
the real power changes come into play.
b18-eg6
Aug 1, 2006 05:23 AM
lsvsol
May 12, 2006 07:03 PM
Richard.
Nov 23, 2003 12:36 PM
Champ R
Nov 21, 2003 03:26 PM
vtecdc2
Apr 29, 2002 01:34 PM
