88-89 si cluster into 89 std.....wiring info needed
Old Mar 30, 2003 | 12:13 PM
shotty's Avatar
Default 88-89 si cluster into 89 std.....wiring info needed
I have an 88-89 si cluster I want to put into my 89 std. Now, if I plug it in it doesnt work. I did find that quite a few wires dont trace to the same things on each cluster. Anyone have some wiring diagrams? Thanks......
Old Mar 30, 2003 | 12:31 PM
subgeniusdude's Avatar
Default Re: 88-89 si cluster into 89 std.....wiring info needed (shotty)
It should be plug and play...or plug and pray...are you absolutely sure it isn't from a 90-91 ?
Old Mar 30, 2003 | 12:34 PM
shotty's Avatar
Default Re: 88-89 si cluster into 89 std.....wiring info needed (subgeniusdude)
Im sure....absolutely sure. It is flat on top. Now, because mine is a STD not a DX that is what I think is the problem. Ive read of everyone plugging them into DX's but I havent heard of anyone plugging an si cluster into a STD
Old Mar 30, 2003 | 02:30 PM
zCivic's Avatar
It was a plug and play for a 90 STD don't see where is should be any different for the 88-89's
Old Mar 30, 2003 | 02:47 PM
zcivicz's Avatar
Default Re: 88-89 si cluster into 89 std.....wiring info needed (zCivic)
its plug and play. i have a CX (std in the US) and i installed an 89 Si cluster without any mods. maybe the cluster you got is defective ?
Old Mar 30, 2003 | 02:59 PM
shotty's Avatar
Default Re: 88-89 si cluster into 89 std.....wiring info needed (zcivicz)
Its not defective. It works just fine. I just traced out all the pins from both clusters and rewired. Works just fine now. Dont worry about any wiring diagrams anymore.
hondanator88
18
Oct 30, 2010 04:10 PM
Mr.Meowsome
12
Dec 4, 2007 05:23 PM
Layziebtnh055
Apr 20, 2004 08:44 AM
Speedfreak
Dec 11, 2002 04:43 PM
exr_pd
May 22, 2002 12:03 PM
