d16y8 head on d16z6 block
Old Mar 30, 2003 | 11:26 AM
CRXb16asir91's Avatar
Default d16y8 head on d16z6 block
Tryin to put d16y8 head on d16z6 block. Got down to the distributor and its not the same. So where do I go from here? Will a d16y8 distributor work with the d16z6 wiring or do I need to some how rework the holes on the head or z6 distributor... All help is greatly appreciated.
Old Mar 30, 2003 | 11:29 AM
orange.honda's Avatar
Default Re: d16y8 head on d16z6 block (CRXb16asir91)
i would go with th y8 dizzy but im not sure if they wire up the same.
Old Mar 30, 2003 | 11:31 AM
can someone tell me if they wire up the same or whats needed to wire it up?
Old Mar 30, 2003 | 12:42 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
We used the old D15 dist. on my friend's Y8 engine swap. The Z6 dist. should work fine.
Old Mar 30, 2003 | 03:57 PM
dude the z6 distributor doesn't line up with the holes on the head.... either you have to just use 2 of the 3 holes and then it sits the distributor way back... surely someone has a solution to this problem
Old Mar 30, 2003 | 05:08 PM
RyanEJ8's Avatar
you have to use the y8 distributor
Old Mar 30, 2003 | 07:13 PM
will it just plug in and if not what wiring mods need to be done?
Old Mar 30, 2003 | 08:12 PM
MrTodd's Avatar
With my setup I'm using an OBD-0 ('90 CRX Si/D16A6) distributor, it lines up perfectly. I assume you have an OBD-1 vehicle, so you'll either want to give any OBD-2 (Y8) distributor a try, or perhaps any OBD-1 Non-VTEC dizzy. I think the 92-95 Dx motor has the exact same head casting as the D16A6, which means the distributor holes should be the same as well. I don't know the specifics on OBD-1 cars, but it's definitely worth it to take a peek at an old Dx dizzy.
Old Mar 30, 2003 | 09:22 PM
Usdm1's Avatar
Default Re: d16y8 head on d16z6 block (MrTodd)
I just completed my D16y8 in my EG6 , you have to use the D16y8 distributor .
All you have to do is rewire the plugs .... What I did is take all the pins out from the 92-95 distributor harness and swap the end of the plug to the Ek harness , Its pretty simple . The only pins that won't fit is the Big black/yellow wire and Dark blue wire , those I just soldered the pins from the Y8 harness and cliped it back together .
You can go the other way around if you dont have the harness from the Y8 dist .
johnwohl
Oct 14, 2008 09:10 AM
Eyal 951
Jul 16, 2006 05:59 PM
Bense
Jan 8, 2006 12:02 PM
BoostdRex
Jul 19, 2005 12:49 PM
vtecrx
Nov 8, 2002 05:18 PM
