what egt does a turbo honda run good at?
Old Mar 30, 2003 | 09:46 AM
Big Josh's Avatar
Default what egt does a turbo honda run good at?
Just wondering if anyone knew what egt a turbocharged honda runs strong at. A friend of mine said that dsm's run strong at 15.5, just wondering what a honda runs good at.
Old Mar 30, 2003 | 10:18 AM
PM-Performance's Avatar
Default Re: what egt does a turbo honda run good at? (Big Josh)
well mine under load, like contant 90mph on the highway is like 1350-1400, and just cruising around town maybe like 1000
i think it will vary on tunethough
Old Mar 30, 2003 | 10:31 AM
jinxproof99's Avatar
New User
Default Re: what egt does a turbo honda run good at? (itr206)
750 - 800 celcius.
Old Mar 30, 2003 | 10:42 AM
COLORPROS's Avatar
Default Re: what egt does a turbo honda run good at? (jinxproof99)
do you guys recomend using one of these..
Old Mar 30, 2003 | 10:58 AM
TurboDANDEE's Avatar
Default Re: what egt does a turbo honda run good at? (COLORPROS)
mine goes up all the way to 880 celcius on 4th gear, 1 bar... is that too hot?
Old Jul 30, 2003 | 06:53 PM
model x's Avatar
Default Re: what egt does a turbo honda run good at? (TurboDANDEE)
at WOT it should be 700-900 and normal cruising it should be around 550-600C assuming that your probe is where it should be, about an inch from the head on the #3 cylinder
Eric R
Aug 26, 2002 07:12 AM
SOHCmycord
Jun 25, 2002 12:49 PM
JM Performance
Dec 25, 2001 03:32 PM
