my power door locks aint working
Old Mar 30, 2003 | 08:47 AM
TheJediMex's Avatar
Default my power door locks aint working
i have a 98 integra ls coupe.. the power doorlocks aint working when i hit the switch.. the guy i bought the car from said it has to do something that start with the letter "A"
maybe a module box or something
yes i checked all the fusses and everything is fine..
any suggestions?
Old Mar 30, 2003 | 08:54 AM
sackdz's Avatar
Default Re: my power door locks aint working (JdmTeg97)
any suggestions?
Hooked On Phonics.
The power door lock circuit is built in to the drivers side controls. Try manually actuating the lock solenoid by unplugging the harness on each side and feeding it 12V. If they both work, check for an open in the wires that run around the front of the cabin between the doors.
Old Mar 30, 2003 | 10:18 AM
TheJediMex's Avatar
Default Re: my power door locks aint working (sackdz)
thanks for the info but
hook on phonics is for learning to read.....
but ill try what you suggested .
and ps sometimes i mistype, cause i type fast and my mind dont catch up with my fingers
Old Mar 30, 2003 | 10:21 AM
sackdz's Avatar
im just giving you a hard time. if i was really that upset by your spelling and typing, i probably wouldn't have tried to help
Old Mar 30, 2003 | 10:25 AM
1999all_motoR_teg's Avatar
Could also be that you need a new actuator. There like $15. That's what happened to me on my passenger side, the drivers side would open and close but the passenger side would either just stay in the same postion or SOMETIMES it would open. Changed the actuator for that door and problem gone.
Old Mar 30, 2003 | 10:30 AM
TheJediMex's Avatar
Default Re: my power door locks aint working (CIVICSKYLINE)
yeah thats the word the guy said the dealer told him he needed to fix the problem
thanks
any pics of where this is or what it looks like?
[Modified by JdmTeg97, 11:32 AM 3/30/2003]
Old Mar 30, 2003 | 10:31 AM
TheJediMex's Avatar
no prob
Old Mar 30, 2003 | 11:50 PM
salbaje's Avatar
if its actuator just check all the wiring. they dont really go bad.
Old Mar 31, 2003 | 02:11 AM
tnbigdawg's Avatar
Default Re: my power door locks aint working (salbaje)
check relay, and fuse. If you have an aftermarket alarm then most likely you have a external relay somewhere zip-tied under your dash.
bonta-kun
Oct 10, 2006 03:14 PM
vwtuner
Apr 27, 2006 07:26 PM
Matgallis
Mar 12, 2005 02:07 PM
TheJediMex
Apr 21, 2003 08:26 PM
gribbs
Apr 11, 2003 04:52 AM
