Need Some Alignment Specs / Camber kit Question
Old Mar 30, 2003 | 06:30 AM
Flux's Avatar
Default Need Some Alignment Specs / Camber kit Question
I am corner weighting the car this next wekend and then an alighment (much needed). I am unclear about what the best alignment settings will be for an R that is primarily an autox car (not a daily driver).
Car is lowered about 1" on coilovers, 10kf/8kr spring rates, JDM rear sway bar. Running Falken Azenis.
Do I need to get a camber kit to get a better alignment?
I have searced and found this thread:
https://honda-tech.com/zerothread?id=445766 with some good info, but would like more info and recommendations of people that are autoxing their R.
What about these settings?
Front
Toe:
L 0.01
R 0.02
Camber:
L -.09
R -1.4
Caster
L 0.7
R 1.4
Rear
Toe:
L 0.01
R 0.02
Thrust Angle: 0.02
Camber:
L -.09
R -1.1
[Modified by Flux, 9:57 AM 3/30/2003]
Old Mar 30, 2003 | 07:10 AM
Asahi's Avatar
Default Re: Need Some Alignment Specs / Camber kit Question (George Knighton)
Have to agree with George a camber kit will probably be needed.
I run -2.0/-1.8 and drive street and Auto-X/Track no problems. If you don't street the car much then I would add a little to the front.
I run 1/8" total toe out in the front and zero toe in the rear. I would run 1/4" totel toe out if I didn't drive the car every day.
Trey
Old Mar 30, 2003 | 07:48 AM
Flux's Avatar
Default Re: Need Some Alignment Specs / Camber kit Question (Asahi)
Thanks guys. At what point does a camber kit become necessary? Should I get one for the fron and rear?
Can you recommend a good front camber kit?
Old Mar 30, 2003 | 08:02 AM
Dropspeed's Avatar
Default Re: Need Some Alignment Specs / Camber kit Question (Flux)
I'm sure you saw it but take a look at page 2 for pics of the Ingalls pieces.
https://honda-tech.com/zerothread?id...774728#4774728
FYI I will be selling my SPC rear camber adjusters as soon as I remove them from the car. Never seen winter or salt, look brand new $70.00 for the pair, I think wholesale is $110 for both
Mattj
Old Mar 30, 2003 | 11:48 AM
Flux's Avatar
Default Re: Need Some Alignment Specs / Camber kit Question (Dropspeed)
ok, so -2 degrees front camber and -1.8 degrees rear camber. 1/8 total toe out in front, zero rear...
What about caster?
Old Mar 31, 2003 | 08:31 AM
Flux's Avatar
What about caster?
Anybody have any recommended caster settings? Is caster even adjustable on an R?
Old Mar 31, 2003 | 08:35 AM
Reid's Avatar
Global Moderator
It's not adjustable.
You can swap control arms to get more, but the "adjustment" ends there.
milanoteg
Jul 10, 2009 07:00 PM
EK k kay
Suspension & Brakes
Aug 27, 2006 10:10 PM
NAB16AEK
Jan 25, 2004 08:00 PM
kay_animation
Nov 3, 2003 06:56 PM
96 SOHC VTEC
Jan 5, 2003 04:34 PM
