axel question. help fast please
Old Mar 29, 2003 | 10:44 PM
CeoStatus0's Avatar
Default axel question. help fast please
my CV boot ripped, front pass side like a month or two ago. but i was told i should just replace the axel. but I'm planning on takeing my car on a 400mile trip back and forth 400miles each way. so 800 miles total.. dose anyone know if this will be ok.. or will it be bad?
Old Mar 29, 2003 | 10:50 PM
Who Said's Avatar
Default Re: axel question. help fast please (pureaznxex)
you could get a boot kit it includes he new boot, grease, and the clamps...but you need special pliers to intsall it
Old Mar 29, 2003 | 10:54 PM
Dancing is Forbidden's Avatar
Default Re: axel question. help fast please (super-dooper fast)
???? I did mine and cant think of any specail pliers I used. If you are mechanically inclined and have access to a hydraulic press then do the cv boot. If not just change the axle.
Old Mar 29, 2003 | 11:01 PM
CeoStatus0's Avatar
Default Re: axel question. help fast please (EF9_SiR)
i don't plan of getting the boot fixed before i take off on my little road trip.. i don't have the time.. main concern is if anyone thinks its just koo riding with my car for lets say another 1000 miles before i fix it. because i don't want to be stranded in the middle of no where haha
Old Mar 29, 2003 | 11:03 PM
Who Said's Avatar
you could get a boot kit it includes he new boot, grease, and the clamps...but you need special pliers to intsall it???? I did mine and cant think of any specail pliers I used. If you are mechanically inclined and have access to a hydraulic press then do the cv boot. If not just change the axle.
well there is a special set of pliers you could use(makes it a hell of alot easier)dont ...snap on, matco,etc sell them ...i never used a hydraulic press...i overhaul maybe 3 or 4 a week at work
Old Mar 29, 2003 | 11:04 PM
just do it. Its less then 75 at autozone. good insurance. cause who knows when its going to go.
Old Mar 30, 2003 | 12:00 AM
Stripped Honda's Avatar
99-0104
hydraulic press what do you need this for you just need a BFH and a pair of dikes rags,and a razor blade i use the dikes to crimp that clamp but i am planning on buying the tool soon
and to answer your question yes you can take it on that drive with no problems but you will have to change the axle after that drive and not just change the boot as the bearings will be bad by then .. but still drivable
Old Mar 31, 2003 | 05:22 PM
Default Re: axel question. help fast please (Stripped Honda)
Well when we did mine, while its not neccessary, we cleaned the bearings out and needed the hydraulic press to get the bearings out.
Old Mar 31, 2003 | 05:29 PM
pdiggitydogg's Avatar
Well...personally I wouldnt want to drive 100 miles on a bad boot, let alone 1000. It could really **** up the cv joint and then you would have a much more expensive repair on your hands...take it to a shop if you dont have the know-how or access to the right tools...I recommend dealer
Old Mar 31, 2003 | 05:36 PM
ace1875's Avatar
Default Re: axel question. help fast please (pdiggitydogg)
Best thing just replace it cause you never know its cheaper to do it then get stranded in some country *** town.
Then you will be yourself for not spending that $75.
From past Exp its best to change it ASAP or else it will rip more shitup then you think.
zero808
Mar 2, 2006 07:43 PM
myuglycivic
Jun 15, 2005 06:39 PM
JCracer723
10
Jan 22, 2004 02:54 PM
mist sITR
Sep 25, 2003 11:02 PM
