What's the trick to removing headlight from a 94 accord
I give up, my fingers hurt like hell trying to screw the damn ring off so I can put in some silverstars. My teg just turns and pulls out.
[Modified by preludexl, 4:22 AM 3/30/2003]
there are a few slots in the ring, take a flathead screwdriver and a hammer and slide the end of the flathead into one of the slits, tap it with the hammer and it will turn, either it will loosen up and turn right away, or youll have to tap it all the way around, either way, it should work. if you need a clearer explaination, drop me a line.
i'll give it a try right now. thanks dude.
While i'm on it, how do you align headlights on these? I dont see any built in centering instruments on.
[Modified by preludexl, 4:36 AM 3/30/2003]
theres a screw on the upper left side of either light to adjust the angle.
they should hit the ground and intersect at about 30 feet ahead of yoru car. to get them level just find flat gound in front of a wall, then turn on the lights, adjust up and down as necessary.
wojtkows
Mar 29, 2010 10:07 AM
tRaCeYoUiNcHaLk
Mar 12, 2008 10:02 PM
vtec26
Mar 1, 2007 05:28 PM
