Torquing sequence and specs needed for B18B intake manifold...
Old Mar 29, 2003 | 06:40 PM
JV's Avatar
JV
Who?
Default Torquing sequence and specs needed for B18B intake manifold...
I'm going be installing a skunk2 IM on my 96 B18B and need the torque
sequence/specs for the IM to head bolts.
TIA
Old Mar 29, 2003 | 08:08 PM
dfoxengr's Avatar
Default Re: Torquing sequence and specs needed for B18B intake manifold... (JV)
doesnt really matter....
about 20lbs per
Old Mar 29, 2003 | 11:01 PM
hybridb18's Avatar
Default Re: Torquing sequence and specs needed for B18B intake manifold... (hybridvteceg)
just tighten them ****'s real good
Old Mar 30, 2003 | 06:34 AM
JV's Avatar
JV
Who?
So i don't need to start from the center and work my way out both ways in a criss cross pattern until the desired torque is reached, like i did on my D16?
"Doesn't really matter", "about 20lbs per", and "tighten them ***** real good", are not the type of answers i'm looking for.
No offense guys, but i only want to have to do this once if you know what i mean...
Anybody have a little more in depth info from a helms or something????
Old Mar 30, 2003 | 07:40 AM
DK4200's Avatar
yes you need to tighten them down from the middle out going in a crisscross pattern. The book says torque them to 17ft lbs. hope that helps
Old Mar 30, 2003 | 10:27 AM
dfoxengr's Avatar
Default Re: Torquing sequence and specs needed for B18B intake manifold... (DK4200)
yeah but its just a manifold...if u didnt want an answer, then you shouldnt have asked... my answer was, that it dosnt matter what sequence, and about 20 lbs....the book says 17 so i WAS right...
[Modified by hybridvteceg, 2:27 PM 3/30/2003]
Old Mar 30, 2003 | 10:33 AM
JV's Avatar
JV
Who?
I don't understand why people get so defensive when you ask for a less vague answer?
Does it make you feel incompetent because your answer was not satisfactory to me?
Try to see it from my point of view before you go getting your tighty whities in a bunch...
Old Mar 30, 2003 | 10:36 AM
JV's Avatar
JV
Who?
Thank you...
Can anybody confirm this? I just want to be positive. I'm guess i'm ****...
Old Mar 30, 2003 | 01:23 PM
dfoxengr's Avatar
no it makes me feel like some people dont know how to figure it out for themselves, and induce the solution from a relatively decent answer. ur not dealing with anything complex here.
Old Mar 30, 2003 | 02:38 PM
b20guy's Avatar
Start from center out, crisscross pattern, 17 ft flbs. Let's do this the right way. Maybe if we give more accurate answers there would be less threads starting like this: "Help! My car won't idle right"
Old Mar 30, 2003 | 02:52 PM
MikeSarr_GSR's Avatar
Default Re: Torquing sequence and specs needed for B18B intake manifold... (b20guy)
bro. its not a head gasket, main caps or rod bearings. thread them all down snug and stop. then tighten them by hand until they stop, and about 1/4+ turn each. start from the middle and work your way out diagonally back
for instance but not limited to:
(09) (05) (01) (03) (07)
(08) (04) (02) (06) (10)
This will insure that the gasket seats somewhat evenly.
Its not that critical, this is about the level of attention
you will need to give it.
Old Mar 30, 2003 | 03:16 PM
JV's Avatar
JV
Who?
That's exactly what i'm talking about...
Old Mar 30, 2003 | 07:09 PM
that being said, your car's idle wont be effected by the IM gasket unless there isnt one. if any stray air gets in there, it will behave like another throttle without a butterfly. the chances of that happening by not getting the TQ spec perfect is nil to zilch
Old Mar 30, 2003 | 07:44 PM
JV's Avatar
JV
Who?
Default Re: Torquing sequence and specs needed for B18B intake manifold... (MikeSarr_GSR)
I got what i need, case closed, good night.
Thanks...
DA is best
Aug 11, 2011 12:33 PM
butoboti
Jan 23, 2006 12:57 PM
JV
Mar 29, 2003 05:10 PM
metal-x
Mar 12, 2003 01:55 PM
kanned
Feb 4, 2003 02:55 AM
