URGENT - electrical problem - in the middle of a swap
Old Mar 29, 2003 | 05:21 PM
serious's Avatar
Default URGENT - electrical problem - in the middle of a swap
i'm the middle of the swap, so i need help URGENTLY. i've swapped a d16z6 into my 90 civic. i'm using the z6 ecu and intake manifold. when i turn the key to the 1 position, the radio comes on and everything is fine. however, when i turn the key to the 2 position, the "check engine" light flashes really fast and the main realy goes crazy clicking really fast. any ideas what it might be?
Old Mar 29, 2003 | 08:11 PM
dfoxengr's Avatar
Default Re: URGENT - electrical problem - in the middle of a swap (serious)
bad ecu?> and will the car start?
Old Mar 29, 2003 | 08:13 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: URGENT - electrical problem - in the middle of a swap (hybridvteceg)
make sure all your grounds are on and tight
batt to chasis
batt to tranny
engine to chassis
sounds like you have the chassis grounded but not the engine
Old Mar 29, 2003 | 10:54 PM
hybridb18's Avatar
did u rewire the car for obd1???? or did u buy a harness for it
Old Mar 30, 2003 | 04:58 AM
serious's Avatar
Default Re: URGENT - electrical problem - in the middle of a swap (hybridb18)
car is rewired to obd1.
Old Mar 30, 2003 | 07:22 AM
Chiovnidca's Avatar
Default Re: URGENT - electrical problem - in the middle of a swap (boostedcivicsir)
batt to chasis
batt to tranny
engine to chassis
Also check the ground wire on the thermstat housing.
Old Mar 31, 2003 | 06:40 PM
Mr. Badwrench
Default Re: URGENT - electrical problem - in the middle of a swap (TurboD16Chiovnidca)
missed that one thanks. i always assume it is connected when hooking up the harness...
f3rcho
Engine Management and Tuning
Jul 1, 2010 06:51 PM
thegoatc
11
Nov 16, 2009 03:01 AM
yellowjdmcrx
Feb 15, 2008 01:00 PM
90datech
62
Jan 11, 2008 06:30 AM
serious
Mar 29, 2003 05:28 PM
