the diff between a JDM typeR and a JDM GSR tranny....?
you cant, cause some JDM GSR (SiR) Trannies have LSD like the Type R.
That is when you can look from one side to the other without seeing a little rod = LSD, if you see the rod = NON LSD.
Both have the same code # on it.
The R have shorter ratios than the Sir as well as A Different LSD.
The R LSD is a 10 bolt, while The Sir is 14.
You would have to open the Tranny to know.
Hope that helps.
[Modified by 4doortypeR, 10:53 PM 3/29/2003]
Hope that helps.
Hope that helps.
Hope that helps.
Grocery Getter
Sep 5, 2003 01:22 PM
