STOCK FLY WHEEL LIGHTENED OR BRAND NAME ???
Old Jun 18, 2001 | 05:07 AM
ITS BONE STOCK I SWEAR's Avatar
New User
Default STOCK FLY WHEEL LIGHTENED OR BRAND NAME ???
I am thinking of doing fly wheel on my car and I want to know what the difference is between shaving my stock one down to 8 lbs or buying a comptech or clutchmasters. what is the difference or is it the same thing ??????????????????????????????????????
also do you need to replace your clutch to be able to handle a flywheel
please somebody helppppppppppppppppppppppppppppppp
Thanks
Old Jun 18, 2001 | 06:53 AM
itrhybrid's Avatar
Default Re: STOCK FLY WHEEL LIGHTENED OR BRAND NAME ??? (slapmyfro)
While I do not know from personal experience, I have heard that shaving the stock flywheel is bad. Especially shaving as much as you want to. Anyone else comment on that one? I personally went with a Toda flywheel. I love it! It revs nicely.
Then there is the great chromolly (sp?) vs. Aluminum flywheel debate. I'm not going to touch that one.
James
Old Jun 18, 2001 | 06:58 AM
Boba-Fett's Avatar
New User
Default Re: STOCK FLY WHEEL LIGHTENED OR BRAND NAME ??? (itrhybrid)
i have the comptech and I love it.
boba- whos motor spins just about as fast as the ITR's on Gran Turismo 2 does with the lightweight flywheel upgrade.
Old Jun 18, 2001 | 07:08 AM
eg6ajk's Avatar
Default Re: STOCK FLY WHEEL LIGHTENED OR BRAND NAME ??? (Boba-Fett)
if you want your flywheel to last and not shatter or warp....do not go less then 11-12lbs....thats the safest weight for a stock flywheel....if you want lighter....then go with either a Fidanza or Toda, JUN or anything else.....
then the choice becomes which material you want to use....
Fidanzas and Mueller are aluminium weight about 7-8lbs and sell usually for about $300 shipped....Toda, Cusco and Excedy are cromoly and sell for about $100-200 more....
if you get your old flywheel, resurfaced, balanced and lightened (quality work) it costs about $100-150.....but its still oem flywheel and its prone to damage....
so sell your ITR flywheel for about $75-100....get the fidanza for $300...and you actually only spent $50 more on a quality flywheel...
Old Jun 18, 2001 | 07:18 AM
Mike K's Avatar
Default Re: STOCK FLY WHEEL LIGHTENED OR BRAND NAME ??? (eg6ajk)
Go with the Comptech/Clutchmasters one. They are the same exact thing. Comptech is sliver, CM is blue. There are about 4 or 5 guys running them locally, including myself. No problems yet, and YES I am a firm believer that aluminum flywheels are better than chromoly.
Later.
Old Jun 18, 2001 | 07:50 AM
PROFILES2000's Avatar
Default Re: STOCK FLY WHEEL LIGHTENED OR BRAND NAME ??? (Mike K)
comptech is 6 lbs and clutch bastards is 8 lbs so thats not the same weight that a lot of rolling weight if u sit down and think about it
Old Jun 18, 2001 | 08:15 AM
New User
Default Re: STOCK FLY WHEEL LIGHTENED OR BRAND NAME ??? (Y2kGsR)
Hey Guys
I have ordered the Excedy which is 9.1 Lbs do you think that I will notice a big improvement in acceleration ??? Will it make that much of a difference and to top it off is that a goof flywheel ???????
Thanks again
Old Jun 18, 2001 | 11:41 AM
rezaroy's Avatar
New User
clutch masters is the way to go, but u have to put the engine mounts in or it won't be as effective. And u can use the stock flywheel thats what they(clutch masters) use to test them. one punch
Old Jun 18, 2001 | 01:35 PM
PROFILE EK4's Avatar
New User
Default Re: STOCK FLY WHEEL LIGHTENED OR BRAND NAME ??? (rezaroy)
engine mounts???????
i had a clutch bastards in my last eg and it made a diffrence in how acceleration and revving was concerned....
now im using a comptech in my ek and damn.....what a diffrence 2 pounds will make...not only does it rev alot faster and accelerate better...but the rpms drop really quick...alot faster than my clutch bastards did.....and its not at all hard to drive with as some people have told me....good luck
Old Jun 18, 2001 | 05:28 PM
Jason's Avatar
What's the weight of a stock flywheel? Just out of curiosity, how difficult is it to install yourself? I know it takes a lot of TIME, but difficulty for someone who is just now learning to work on cars. If too difficult, what's approx. cost to have someone else do it.
thanks guys
Old Jun 19, 2001 | 05:13 PM
Digital-R's Avatar
Nope, the difference is less than a pound. Comptech is 6.75 and Clutch Masters is 7.5 , which equals ......a mere .75lbs difference
Do-Work
21
Jul 8, 2009 07:06 PM
whitehf
Feb 4, 2006 05:20 AM
ItalynStylion
Dec 7, 2004 10:50 AM
Nate B
Sep 11, 2002 04:23 AM
au-gsr
Apr 16, 2002 11:44 AM
