Where to get guages fixed?
Where can I go to get a tach and speedometer fixed?
Any auto shop in your area should be able to take a look at it or.....gasp.....dealer?
Not going to the dealer...
And ive already asked before and no one helped with the problem, so I didnt see why posting the problem AGAIN would resolve anything.
When I turn the key to "ACC" my tach and speedo needles jump to like 1k rpm / 2-mph as if they had power - so when I start the car, this is where the needles "zero" at so then the tach will read liek 2k rpm and obviously my speedo is way off. I took them out of the cluster and theres nothing obvious there I can fix.
Ive traced the back, cleaned it - got no differance. Pulled each one semi apart to see if anything looked burnt, everything looks normal. Im guessing its in the actual "can" part of it, but why BOTH guages do this at the same time is beyond me. Its like theres power getting to them before it should be...
mugenhatch92
Mar 29, 2006 07:21 PM
Braco11
Mar 31, 2003 09:55 AM
