Its been covered a hundered times anybody got an answer yet
Old Mar 29, 2003 | 09:06 AM
Stryker908's Avatar
Default Its been covered a hundered times anybody got an answer yet
EG's leaking .... I have a leak on my drivers side some where, the floor gets wet .. thats it ... nothing else PLEASE HELP ME ! I am sick of this mildew smell !
Old Mar 29, 2003 | 09:52 AM
Stiz24's Avatar
Default Re: Its been covered a hundered times anybody got an answer yet (Stryker908)
I dont know, but my window leaks on my EG. Everytime I wash it I end up having to sit on a wet seat and the floor is a little wet. A possibility?
Old Mar 29, 2003 | 10:21 AM
SymphonyX's Avatar
i had this problem, try this, take out your carpet and everything else, then jack up your car and have a friend get the water hose and spray up underneath the car, water should come out somewhere, then get silcone and glue it up or sheet metal with jb weld.
Old Mar 29, 2003 | 10:27 AM
sammysnakes's Avatar
check the seals around your windshield. also, a friend of mine had one of his drain plugs in the floor board came loose, which would soak his carpet everytime it rained. we didn't what it was until he took his carpet out and noticed the plug wasn't in the hole anymore.
edit: spelling.
[Modified by chainsaw, 1:31 PM 3/29/2003]
Old Mar 29, 2003 | 10:28 AM
xXx Justin xXx's Avatar
Default Re: Its been covered a hundered times anybody got an answer yet (Stiz24)
replace the weather stripping around your door. and check the latch that the door attached to whe u close it. make sure when you close it, it is allowing it to close tight and make a seal. if it closes flush with the rest of the car, then it is just a $5 rubber weather stripping that runs around your door. hope that helps you.
but when i have my carpet out re-doing my interior, i noticed the tiniest amount of water leaking in right under the ecu. only in a hard down poor, barely any water. and mine also leaks a litle in the rear somewhere from the foof? i still have my headliner and back panels out... i need to fix that.
Old Mar 29, 2003 | 11:05 AM
JDMH22HATCH's Avatar
Default Re: Its been covered a hundered times anybody got an answer yet (SOHC Beast)
Make sure all the grommets in the firewall are ok. There are a few spots on my car I had to fix because whenever I would hit a big puddle, water would slightly splash on my feet.
Old Mar 29, 2003 | 11:26 AM
B16Ej1's Avatar
Default Re: Its been covered a hundered times anybody got an answer yet (PIMPASSBEOTCH)
i feel your pain i have a leak on my pass side front floor ... ended up being condensation from my heater case ...the drain was pluged up... took the case out and drained damn near a gallon out of it ....doesnt really help you guys but just wanted to say that..........
i had this same problem on my old eg hatch, but then one day it just stopped getting wet, this may have been my problem
Old Mar 29, 2003 | 09:10 PM
Stiz24's Avatar
thanks man, that's probably what it is, and happened during the paint job, cuz that sheeit doesnt go back together the way it came off but it just looks normal?? who knows, wouldnt hurt to replace it
Old Mar 29, 2003 | 10:13 PM
stockegsix's Avatar
TTT... i have this problem too, my EG driver side carpet gets soaking wet when it rains.
Old Mar 29, 2003 | 10:17 PM
Stryker908's Avatar
Default Re: Its been covered a hundered times anybody got an answer yet (zzZZzzleeperCX)
haha and guess what its raining again tonight ... Monday I think im going to take my car to an auto glass place and have them take the windshield off and put it back on ... resealing it .. the next option is leaving it at a body shop where they can leave a hose on on it and fix the problem for me .. im tired of seaching by my self .. im just gonna pay somebody to fix it !
Old Mar 30, 2003 | 11:55 AM
dose's Avatar
if its an si check the drain tubes from the sunroof,youll have to pull down the headliner
Old Mar 30, 2003 | 12:00 PM
DXRiCE98's Avatar
Default Re: Its been covered a hundered times anybody got an answer yet (dose)
It's the seal around your door. Either the weather stripping has worn down, or the door has once been removed and replaced by someone who didn't know what they were doing. You can adjust the strike plate for the latch and check how the hinges are mounted. I've had this problem on two of my Civics.
Old Mar 30, 2003 | 12:12 PM
CTR_EK9's Avatar
Default Re: Its been covered a hundered times anybody got an answer yet (DXRiCE98)
I Know the answer!!! When is rainning set ur heater at recycle, not in fresh air! Ur car is fine. I had the some problem.
Berto028
Jan 21, 2017 07:35 PM
kungpaoturkey
Jan 5, 2011 07:16 PM
efsedanfan
14
Nov 10, 2008 03:33 PM
sophie2005
Jan 6, 2007 02:16 PM
BadEH2
Mar 24, 2005 09:59 AM
