post your suspension setup, sway bars included..
Old Mar 29, 2003 | 08:21 AM
TurboBumblBee's Avatar
Default post your suspension setup, sway bars included..
im currently working on my suspension now that the motor is all swappd and running.. im getting some ultima shocks for the front and rear, i have skunk2 coilovers taht were a hand me down under my bed.. now im stuck on what sway bars i should go with... what does everyone suggest??? ST or oem itr and gsr.. what is easier? i know w/ the its i need the beaks kit.. i want something that will handle wheel for street and drag strip use.. im not currently into any autox at all.. i would like to stay under 300-350 for the front and rear sway bars if possible.. thanks
Old Mar 29, 2003 | 08:27 AM
Damon's Avatar
Default Re: post your suspension setup, sway bars included.. (Hybrid95CivicEX)
password JDM (www.passwordjdm.com) sells the front and rear ITR sway kits for like $79 each. Toss in a beaks kit for $65, and you are still less than $300 for a superior setup.
-JDM Honda ITR Front Strut Tower Bar
-Spoon Sports Rear Strut Tower Bar
-Ingall's Front Camber Kit
-Ingall's Rear Camber Kit
-Eibach Pro Kit
-KYB AGX Shocks
-Skunk2 21mm Rear Sway Bar
-Skunk2 Rear Lower Tie Bar (Titanium)
-Custom Welded Rear Subframe w/ Beaks Reinforcing Plates For Sway Bar
-Stock Civic Si Front 26mm Sway Bar
[Modified by Damon, 11:34 AM 3/29/2003]
Old Mar 29, 2003 | 08:37 AM
Dr. EKology's Avatar
Comptech's got an excellent rear sway set-up but it would probably put you over your budget so I would probably go with ITR w/ Beaks.
Old Mar 29, 2003 | 08:43 AM
ITRacer121's Avatar
Default Re: post your suspension setup, sway bars included.. (Damon)
that sounds like a pretty good Idea
but I thought he would have to buy LCAS and all that crap to use the ITR bars
I would just buy the ST for a little more and know they fit on your car
and get the beaks kit too
-eibach pro kit
-tokicko 5 ways
-USDM type R strut bar (off my type R -> she got a mugen)
-eleven strong bar and lower tie bar
-ST front and rear sway bars
another reason I back up ST is that I bought my sway bars from a local guy that wrecked his car befor he installed the bars well I was thinking all civics would have to be the same
but I got the front one for the civic with the OEM front bar so nothing fit right!
I called up ST and they sent the parts for free (all I payed was shipping) and I had them 2 days later!
everything works great even with me beating on it regularly
ST=GOOD CUSTOMER SERVICE AND RELIABILITY
other wise I would give comptech some seriouse consideration
thier product quality is BADASS and I really like all thier stuff
but I would get a front sway bar on at the same time as the rear or else you will be tail happy
[Modified by ITRacer121, 5:45 PM 3/29/2003]
Old Mar 29, 2003 | 08:47 AM
kommon_sense's Avatar
Default Re: post your suspension setup, sway bars included.. (ITRacer121)
Nope. He doesn't need ITR rear LCAs to use the ITR bar. I believe that you use the 99-00 SI endlinks for the ITR bar.
Old Mar 29, 2003 | 09:13 AM
Just be very carefull with ST bar, there have been many people who have ripped out their I-beams and subframes.
Old Mar 29, 2003 | 10:05 AM
Jackson's Avatar
Default Re: post your suspension setup, sway bars included.. (kommon_sense)
How would a sway bar made from honda not fit on the car?
The si endlinks imply to people who drive ek's. He looks to have a 95 civic so he will want to use gsr lca's if he doesnt alread have a rear swaybar stock on his civic. The itr lca's will work too, but then he will need new shocks.
Old Mar 29, 2003 | 10:49 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Re: post your suspension setup, sway bars included.. (Jackson)
I thought you could use the ITR endlinks with an EG (I believe you can). I nany event.
I had:
Neuspeed Race springs
KYB AGX's
Neuspeed Front Lower Tie bar
Neuspeed Rear Lower Tie bar
ITR strut tower bar (I'm selling this if any is interested. The ends are black and it doesn't have the ITR decal on it anymore)
I sold everything (ITR bar still up for grabs).
Whne my car gets out of the shop I'm installing:
Tein SS coilovers (Bought already)
Front/Rear ITR upper Strut Tower bar (On the Way)
JDM ITR Rear sway bar
Beaks Reinforcement kit
Front/Rear Lower Tie (beuspeed)
And I will be ordering a set of custom spring rates from Tein for track days soon.
Old Mar 29, 2003 | 11:13 AM
GokuSSJ4's Avatar
Default Re: post your suspension setup, sway bars included.. (EKology)
Tein suspension
SI/CTR front sway bar
SI rear sway bar
Spoon strut bars f/b
[Modified by Spoon1, 8:13 PM 3/29/2003]
Old Mar 29, 2003 | 11:22 AM
racecarpete's Avatar
Default Re: post your suspension setup, sway bars included.. (Spoon1)
G/C coilovers with custom rates
Koni yellows
Neuspeed front strut bar
Comptech sway/tie bar combo
srr Rear LCAs
Skunk2 front camber kit
Ingalls rear camber kit
[Modified by SilverCivic2k, 12:23 PM 3/29/2003]
The Si
Suspension & Brakes
Mar 12, 2007 11:29 PM
Manolo
Suspension & Brakes
Jan 18, 2006 08:15 AM
dtrtw
Feb 13, 2005 10:53 AM
turbotime
Jul 14, 2004 03:43 AM
fungus@school
11
Sep 1, 2001 02:27 AM
