air temp sensor?
Old Mar 29, 2003 | 02:02 AM
sailor's Avatar
Default air temp sensor?
does anyone know what sensor this is: its an air temp. sensor located underneath the distributor goin into the block, is a 2pin clip on sensor. i dont think its the ect because that one is next to the top rad. hose. (97accord lx 4cyl non vtec)
Old Mar 29, 2003 | 02:16 AM
7PSI CRX's Avatar
Default Re: air temp sensor? (sailor)
That is a water temperature sensor.
That is the one that the ECU sees.
There are three water temp sensors on your car.
1 for the ECU
1 for the temperature gauge (The one pin sensor right next to the one you mentioned)
1 for the radiator fan relay (Either on the thermostst housing or the back of the engine block)
poysenrock
Dec 17, 2006 03:12 PM
ahloung
Mar 15, 2006 11:59 AM
john457
Dec 21, 2005 08:59 PM
Adam_F123
Mar 18, 2004 05:18 AM
