will 96-00 ultima shocks fit a 92-95??
ive got a good deal lined up right now w/ a guy at work for some ultima shocks for a 99-00 civic si, he is selling cause he doesnt own the car anymore and never installed them.. im pretty sure they will fit my 95 coupe but need to make sure.. i heard something about the front fork thingy.. will they fit my car?? please let me know.. im going to be using them w/ skunk2 coilovers and probably ST sway bars.. thanks
You re-use (at least I did with my Tein RAs) the front forks off the lower half of the shock.
However, the bushings on the 92-95 rear LCAs are about .5-.75" too wide for shocks designed for a 96-00 Civic.
I know this because I have Tein RA for 96-00 on my 93 CX Civic. If you shave down the bushing in the rear they will probably fit though.
Good luck
Good luck
thanks man.. can anyone verify that skunk2 coilovers will work with this shocks as well??? thanks
and what sway bar setup should i go with?? ST or get oem itr and gsr front??
the front shocks will fit but the back ones wont fit the fork is smaller on the 96-00 then the 92-95.
bmoua
Jul 7, 2007 12:56 PM
JDMDC5888
Apr 4, 2004 06:20 AM
