will this throttle body fit?
Old Mar 28, 2003 | 08:01 PM
tek_civic's Avatar
Default will this throttle body fit?
so i went to the junkyard today and found myself an integra. i decided to nab it's throttle body so i started wrenching away and within minutes it was in my hand. after it was off i looked at the block some more and thought it was strange(actually most b-series are to me) well it turns out that the car is a pre 94 and the engine is a ZC(says so on the block) did the older tegs come with ZCs? can i use it's throttle body on my d16z6? will it make any difference? i saw another teg that is a pre 94 teg with a b18a should i try to go get that TB insted?
Old Mar 28, 2003 | 08:13 PM
delslow94's Avatar
Default Re: will this throttle body fit? (tek_civic)
i would assume so. i know that the b16a2 and a3 fit on them...might be worth trying. let us know if it works if u get it.
Old Mar 28, 2003 | 08:20 PM
tek_civic's Avatar
Default Re: will this throttle body fit? (delslow94)
ok, so other b series TBs fit on the ZC? if so then the ZC should fit on my d16z6. oh and does anyone know the size of the zc tb? tnx
[Modified by tek_civic, 10:20 PM 3/28/2003]
Old Mar 28, 2003 | 08:27 PM
YumVTEC's Avatar
there's probably no difference in size between the zc tb and your tb.
Old Mar 28, 2003 | 08:32 PM
tek_civic's Avatar
Default Re: will this throttle body fit? (YumVTEC)
really? damn, well just for your info it is the DOHC version ZC if that helps.
messeduprex
Oct 9, 2003 05:07 PM
respectblades
Apr 25, 2003 11:07 AM
tek_civic
Mar 30, 2003 01:06 PM
