Is this unsafe/bad?
Old Mar 28, 2003 | 04:52 PM
Yokohama's Avatar
Default Is this unsafe/bad?
I noticed that the lower control arms on my 1995 hatch look crooked...they dont look like that on my Si...so what's the deal here?...do I need to replace them or are they supposed to look like that?
Thanks!!!
Old Mar 28, 2003 | 04:54 PM
Blue-Civic-Hybrid's Avatar
Loved
Default Re: Is this unsafe/bad? (YokohamaSiR)
wow..I've never seen that, I'm guessing they are bad or bent on purpose.. might want to get those replaced...
Old Mar 28, 2003 | 04:56 PM
SRDrag's Avatar
Default Re: Is this unsafe/bad? (Blue-Civic-Hybrid)
they are like that...
Old Mar 28, 2003 | 05:04 PM
Archidictus's Avatar
Unceasing Measure
Default Re: Is this unsafe/bad? (RIGHTHANDDRIVEITR)
look for heat marks on the high part of the bump. if you clean the grime off and there are noticible marks from shock or high-friction, they're bent. if not, they're made like that.
Old Mar 28, 2003 | 05:06 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Is this unsafe/bad? (Archidictus)
maybe he car got towed with the hooks put there. i cant remember mine bein bent like that.
Old Mar 28, 2003 | 05:09 PM
Mr. Badwrench
Default Re: Is this unsafe/bad? (boostedcivicsir)
looking again i dont think they are supposed to be like that. look at the bottom of the shock. it should be parallel with the lower control arm mounting at the frame. then look at the bushing that bolts it to the spindle. my guess is it got hooked up there and towed like that. i have seen that on front control arms.
Old Mar 28, 2003 | 05:13 PM
92civicsi's Avatar
mine are straight(sp?) ahah
Old Mar 28, 2003 | 05:18 PM
kommon_sense's Avatar
Default Re: Is this unsafe/bad? (92civicsi)
They should be straight. Being bent like that will cause binding during suspension travel. I would get those replaced and then get an alignment. You could snag a set from a junkyard for less than $50, or go with some aftermarket units like SRR or SSR, can't remember which one.
Old Mar 28, 2003 | 05:31 PM
iH8RICERZ's Avatar
Default Re: Is this unsafe/bad? (kommon_sense)
yeah..i dont think that looks right........like what the others have said, i believe it should be straight as well
Old Mar 28, 2003 | 05:33 PM
Hammett's Avatar
Default Re: Is this unsafe/bad? (iH8RICERZ)
mine is straight. never seen that before, i think there is something wrong with yours.
Old Mar 28, 2003 | 05:34 PM
Yokohama's Avatar
Yeah I didnt think so cuz on my '93 hatch they were straight...I only remember that becuase I had to replace two bushings and they were straight...Thanks for the advice guys!
Old Mar 28, 2003 | 06:34 PM
sammysnakes's Avatar
definitely bent. i have the stock lcas from my EH right in front of me and they're straight as an arrow.
Old Mar 28, 2003 | 06:37 PM
b18c1_eh2's Avatar
straight y0
Old Mar 28, 2003 | 07:03 PM
JV's Avatar
JV
Who?
Default Re: Is this unsafe/bad? (chainsaw)
Yeah, i don't remember my stock ones being bent at all. Now my GSR LCA's are a different story...
ekhatchey
Jun 5, 2011 07:37 PM
drtyhatch
Jun 17, 2008 12:10 AM
Draggin99Si
Jul 30, 2006 12:35 AM
fsck3r
Jun 2, 2004 07:33 PM
Amuse9
Oct 26, 2002 07:18 PM
