GSR steering rack into 5th gen Civic
Old Mar 28, 2003 | 04:04 PM
rattletrap's Avatar
Default GSR steering rack into 5th gen Civic
I have access to a low mileage GSR steering rack and crossmember.
Is this a bolt-in affair or are modifications needed?
Thanks in advance.
Old Mar 28, 2003 | 04:16 PM
91DA9's Avatar
Default Re: GSR steering rack into 5th gen Civic (rattletrap)
What year GS-R rack?
Old Mar 28, 2003 | 04:54 PM
Katman's Avatar
Thanks in advance.
if its a 94+ GSR rack and x-member, yes it will bolt up to an EG chassis. You might not like the GSR rack/pinion though. I personally tried one out about 1.5 years ago; yes, the turning radius was much shorter than the civic rack&pinion, but if you try and turn the wheel all the way to the left, it does not go as far as it would with a civic rack&pinion. However turning the wheel all the way to the right, went all the way (same as civic rack/pinion).
Not being able to get the full radius left hand turns urked the living shiz outta me; I eventually went back to the civic rack/pinion..
[Modified by Katman, 5:57 PM 3/28/2003]
Old Mar 28, 2003 | 05:58 PM
NiiS's Avatar
Default Re: GSR steering rack into 5th gen Civic (Katman)
KATMAN, who constantly delivers the g00ds
I should really get you an ECU to chip for me one of these days.
[Modified by sinister, 7:23 PM 3/28/2003]
Old Mar 28, 2003 | 07:11 PM
rattletrap's Avatar
Thanks Katman, thats exactly what I was looking for.
Not doubting your skill, but are you sure you connected the steering column to the rack correctly?
Also, exactly how much quicker is the steering ratio than the Civic power steering rack?
Old Mar 30, 2003 | 10:04 AM
Katman's Avatar
yep, lined everything up. it was about 1 to 1.5 turns less than the civic rack..
Old Mar 30, 2003 | 12:23 PM
92sleepR's Avatar
New User
Bolts right in but you will need the teg steering shaft U-joint as well. Easilly found at any junk yard. There are two advantages to this swap IMHO. the first is that you get a slightly faster ratio and the second is that the Teg rack doesn't have quite as tight a turning circle lock to lock which means larger tires (205-215) won't rub the frame (something that always pissed me off about the civic)
Mike
jdm 1080p
Oct 24, 2011 09:40 AM
vc
Nov 13, 2006 01:04 PM
Spartanic
Jul 13, 2003 11:44 PM
MACHINE
Feb 15, 2003 07:11 PM
magicwand
16
Jul 18, 2002 05:27 AM
