A few turbocharging questions
Old Mar 28, 2003 | 12:54 PM
Del Soul's Avatar
Default A few turbocharging questions
Planning on turbocharging a B18C:
1. I'm going to use sleeves (84mm or so), but do these just drop in or do i have to do some work to get them in?
2. What type of camshafts are best for a turbocharged engine? (I heard that hi-rise or long-duration are bad choices)
3. Is higher compression or lower compression better for turbocharged applications?
4. Would a larger throttle body be a good idea? Also, porting, polishing ($!!), etc..
Old Mar 28, 2003 | 03:06 PM
alpha's Avatar
Default Re: A few turbocharging questions (Del Soul)
Is the search funtion still not up
1) No you can't install sleeves yourself. You have to have a good machine shop install them.
2) Correct. GSR camshafts seems to be everyone's first choice.
3) Higher compression = faster spool, less room for error when tuning and higher power numbers at low boost. Lower compression = slower spool, more room for error when tuning and more boost.
4) You could put your money in better places (tuning)
slowcrx954
Nov 23, 2006 07:49 AM
TehMoonRulz
May 16, 2005 01:15 PM
madcrossover
Dec 13, 2004 06:40 AM
Slomo_civic
Feb 18, 2004 02:27 PM
Fatty_1775
Mar 7, 2003 02:31 PM
