4pt racing harnes???? (sparco clubman)
here is an install for a four point scroth harness in a rsx.
http://www.soloracer.com/rsxrallye4.html
hope that helps.
didn't sparco send instructions with the harness?
hope that helps.
The bottom two harness straps bolt into the rear seat-bracket connections (one on each side, obviously) under the seat bracket. Use the supplied, longer bolts.
The top two straps bolt into the rear driver's-side lower seatbelt hole and rear seatbelt connector, respectively. Cross the straps: the right one to the left hole and the left to the right hole. Be sure to put all of these UNDER the existing hardware for the stock seatbelts.
It's easy as hell and should take you all of 20 minutes. Good luck
ranta18
Feb 27, 2003 02:54 PM
