I hate my brakes!
Old Mar 28, 2003 | 09:37 AM
NoLipRacen's Avatar
Default I hate my brakes!
ive got a little dilema ok. i bought a brake kit through landspeedracing that included powerslot rotors, axxis pads, and goodridge brake lines. i was doing the install myself when i realized a problem. that with the powerslot rotors on there the axxis pads physically wont fit because the rotor and pads are so thick. everybody tells me i need these pins to hold the caliper open but honda said they should drop right in. i am so confused and my brakes are soo shitty right now its unbelievable. thanks guys.
Old Mar 28, 2003 | 10:17 AM
Honda318dx's Avatar
Default Re: I hate my brakes! (LudeTuner)
The piston has to be pushed back into the caliper.. Then the pads will drop in..
Old Mar 28, 2003 | 11:09 AM
DsITR's Avatar
Default Re: I hate my brakes! (Honda318dx)
werd.
If it is to hard to get the piston back in..you can either get a C-clamp (hopefully will fit in there.) or a nifty caliper seperating tool from your nearest AutoZone/Checker..
Old Mar 28, 2003 | 12:55 PM
NoLipRacen's Avatar
have you ever used this setup before?
Old Mar 28, 2003 | 01:04 PM
Boostless97Lude
Guest
Posts: n/a
that doesn't matter, thats what you have to do for brakes, its standard operating procedure
Sam, who is currently on his way to ASE certification in suspension and steering, brakes, and engine performance
Old Apr 9, 2003 | 11:25 AM
DsITR's Avatar
Default Re: I hate my brakes! (Boosted97Lude)
This is prolly a lil late but..
I did my rearbrakes this weekend and;
To push the piston back into the caliper you have to rotate it clockwise into the caliper...you can't just push it in.
The piston has an X in it...just get an open end wrench/pliers and spin it back into the caliper...Then the pads should drop in.
Before you drive, just pump the brakes a few times until the reach normal pressure, then you should be good to go.
PS
This was the rear brakes only on a 97 SH.
Old Apr 9, 2003 | 04:48 PM
Teen Heartthrob's Avatar
Default Re: I hate my brakes! (dsludefosho)
hey ludetuner, let me know how the brake line install goes. I myself will be replacing the pads/rotors/lines as well next weekend.
Old Apr 9, 2003 | 04:59 PM
Shakes's Avatar
space cadet
a pipe wrench works wonders. place one end into the split of the caliper right on the old pad. and the other on the outside. squeeze and they should recess. do the same for the other side. now dropout the old pads. place the new ones in. slide the rotor in and bolt it back into place.
Old Apr 9, 2003 | 06:36 PM
DsITR's Avatar
Default Re: (shakes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shakes &raquo;</TD></TR><TR><TD CLASS="quote">a pipe wrench works wonders. place one end into the split of the caliper right on the old pad. and the other on the outside. squeeze and they should recess. do the same for the other side. now dropout the old pads. place the new ones in. slide the rotor in and bolt it back into place. </TD></TR></TABLE>
That works on most calipers...I've done it on Dodge Rams/Chevy S10's. But it wouldn't work on the Lude, even w/the brake caliper tool..
Just twist the piston clockwise, it will recede back into the caliper, and stay there...and it wil seperate, slide the pads in and put the caliper back on..
Just another token of how good Honda Engineering is...they eliminate the need for the extra tool.
Old Apr 9, 2003 | 07:32 PM
marshdoggg's Avatar
Default Re: (dsludefosho)
ya i replaced my calipers(legend gs)rotors(brembo blanks)pads(aem)and brake lines(stainless) last week. you just have to push the caliper piston back in there...its not too hard. i hope he got it figured out
Old Apr 9, 2003 | 08:41 PM
TimeRacer's Avatar
The rears are the only ones that need to be rotated
Old Apr 10, 2003 | 08:25 AM
Boostless97Lude
Guest
Posts: n/a
we do tire changing at my dad's store, and we have these bigass prybars that looke like screw driver...... i'm talking lik 2" wide too... yeah, thiose things are the **** for rear brakes
Old Apr 10, 2003 | 11:11 AM
IloveNewt's Avatar
Default Re: (Boosted97Lude)
vises work well, as it pushes in it also turns it since ur screwing it in....
Old Apr 10, 2003 | 11:19 AM
DsITR's Avatar
Default Re: (MordecaiPSI)
I honestly don't know why you guys are using These huge *** tools, to do a simple job though. (That is Sams style though... )
I just used an open end wrench, stuck half of it in the caliper...turned it by hand.
Maybe my brakes were softer...I had both calipers off, that what you guys did.?? Mind you, I only did my rears...Waiting for NSX/Legend setup for the front.
Old Apr 10, 2003 | 11:27 AM
Boostless97Lude
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dsludefosho &raquo;</TD></TR><TR><TD CLASS="quote">I honestly don't know why you guys are using These huge *** tools, to do a simple job though. (That is Sams style though... )</TD></TR></TABLE>
if it ain't broke, you didn't use a big enough hammer
BrakeExpert
Suspension & Brakes
Apr 9, 2012 05:59 PM
Dann6968
Suspension & Brakes
Mar 7, 2010 07:51 PM
mjrage
Aug 19, 2004 07:56 PM
st0ne
11
Jun 4, 2003 03:41 PM
blkbeast
Jan 14, 2002 12:58 PM
