f22 Vtec?
my friend has a 96 accord 4dr with the F22A in it and i was wondering if there is a Vtec head that would match up to the block, what other parts would be needed and how much it would cost. Also how would the performance compare to doing an H22a swap. thanx guys
why not? It just bolts right up without any modifications and just needs the VTEC solenoid to be wired into the new ECU. I assume that the former response was talking about a h22a head on the f22a block - and in that case, he is correct, but if we're talking about the f22b1 then shoot, it's a cheap way to gain 5hp over the f22a6.
[Modified by 92Lx, 6:50 PM 3/28/2003]
So with my factory f22a in my accord right now (90 accord lx coupe) I can put a vtec head from the later accord (94-97) on my engine and it bolts right up? I know I need an ecu and also a vtec solenoid and other things, but it cant bolt up?
It's not just the head you'd have to change. You'd have to change the manifold, add some wire for the O2 sensor, do some wiring for the VTEC, change the ECU, and a few other things I'm not sure about. I don't think the bang for the buck would be too good.
Allot fail to realize that some people just have access to these parts at a really good price. And it's not a bad way to get some more power. So it's not really a waste of money to some. But maybe a waste of money to other because they have to pay to much for the parts and then pay someone else to put it in for them.
But if you wanted to do it for lets say a 1990 LX then you would need the head, P0A ECU (1994-1995 EX ECU), Intake manifold, exhaust manifold, and alittle cutom work on the exhaust because of the difference in headers. You won't need any extra O2 sensor wiring (You would if you where converting OBD-O to OBD-1 but the 1990 Accord is already OBD-1) and all you'll need to do is run in the two wires for the Vtec solonoid to the ECU.
So each to his own. You could do this conversion yourself for between $300-$500 depending on your source for parts.
It's not a bad idea considering all you gain (More power, tunable ECU, etc.). Now is that worth the money to you???
500 is 1/4 of an h22. nuff said.
I don't know where your mentallity but consider this. If you invest 2K on your F22B1 you'll blow the doors off any stock H22 swapped car. nuff said.
you also have to drill some oil lines into the block to match up with the vtec head. then with crap like this you have to wonder how reliable it will be especially if your doing it to some old motor.
i was selling a full F22b1 swap with 100k on it for $450, that is your best bet.
if you can get the parts for cheap, why the hell not??? im sure you could get the head and manifolds off a junked ex for pretty damn cheap. if you cant afford the swap, why not do this in the meantime???
thats funny...you throw you 2k into a f22b1 let me know how much power you make out of it, sure throw it on the bottle and after you fry your piston rings then we will talk about the 2k you blew
A head swap on a f22a is not a terrible idea if you want to do an all motor build, if it is preparation for FI then it is not really worth it
A head swap is not a great bang for the buck unless you have access for everything very cheap
consider the h22a long block on an f tranny, h22a long block = only $1200 for a gain of roughly 75-65hp, thats bang for the buck....
you guys were talking about a complete swap being cheaper here is one for REAL cheap but you will have to sell the auto tranny http://cgi.ebay.com/ebaymotors/ws/eB...category=33615
Nick M, are you buying the idea of an H22 swap with the original F-tranny? I am convinced that with proper tuning oriented towards torque, even without FI, it could be an excellent compromise between power and fuel economy. Of course, the 92 fuel...
everyone with such strong opinions about it has never driven one, its not that bad, the lude tranny would give me alittle bit more acceleration, but in actuality its ok, my car traps at 93mph
before i decided on whether or not to keep my F tranny or just wait longer and get an H tranny i drove a 96 prelude vtec and a 99 base model vtec
with my Aasco flywheel, no AC or PS and a straight intake (see the wrapped intake thread), the throttle response and the quick revs sorta make up for the longer gears, when people ride in my car they dont even know its an accord tranny until I tell them
with that said, it does work fine, but an h22a tranny is ideal whether its for NA or FI, long gears and FI are just a myth
the extra 3mpg u get with the F tranny or whatever on the highway is a trade off for alittle acceleration i guess, but this isnt a site about fuel economy, i could care less about mine
the f22 gears seem so long on an f22 because they have no power lol, 145hp in 2950lbs isnt fun
i know someone who used to have a h22 accord with an f22 tranny and he could only get 15.5 in the 1320. the accord tranny on an h22 sucks.
i know a guy a Type R that cant crack 15.5 either, what does that prove? Just that hes a bad driver
great
