? 88 motor in a 90
Old Mar 28, 2003 | 04:46 AM
CRXracer88's Avatar
Default ? 88 motor in a 90
ok heres wut i doin first. i have a 90 si crx the motor in the car is shot but i have an 88si motor and tranny. my ? is will the wiring harness on the 88 motor work with 90 wiring harness under the hood .... the guy that i bouhgt the car from said that theres like two wires i have to switch if i put the 88 si motor in. any help thanxs
Old Mar 28, 2003 | 06:39 AM
Louie B.'s Avatar
Default Re: ? 88 motor in a 90 (CRXracer88)
if they're both si's, there shouln't be any difference in the wiring.
If I were you I'd keep the 90 si tranny and use the 90 flywheel, clutch, and pressure plate unless there's something wrong with it too.
Old Mar 28, 2003 | 06:47 AM
Broken Gearbox's Avatar
Default Re: ? 88 motor in a 90 (thumpu77)
sorry for stealin the thread but do you how hard it would be to drop a 89 D16A6 motor in a 91 DX...D15B??...its a 4spd...can you use the stock axles on the D15?
Old Mar 28, 2003 | 07:34 AM
Proper's Avatar
Default Re: ? 88 motor in a 90 (x lP lL i c i t)
The should be no wiring conflict at all. Just used you old intake manifold and bolt it up to the new motor. Everything will be the same.
As far as the Si motor with a 4spd it should drop right i if you don't swap the inyake manifolds. Then you'll need to do an MPFI conversion. Good luck both to of you
Old Mar 28, 2003 | 07:40 AM
USDM 4G VTEC's Avatar
for the first guy
just take ur 88 Si engine and put ur 90 flywheel , clutch and tranny on it. ready to go....
for the other guy.. u need to convert from DPFI to MPFI (search here its broken i guess.. so go to my sig) after that u can use the Si tranny with it.... and u can still use ur stock mount, axles, shift linkage and all.... jut basically changin engine/tranny and the wiring changes (wich need a new ECU of course)
adeline
Apr 14, 2008 02:35 AM
eLUDEnu
15
Oct 22, 2004 10:20 AM
xsellxoutx
Feb 12, 2003 03:55 PM
xsellxoutx
Feb 10, 2003 08:28 PM
wu tang
14
Dec 20, 2001 07:19 PM
