H22A O2 Sensor Help
Old Mar 27, 2003 | 10:16 PM
hungy's Avatar
Default H22A O2 Sensor Help
Have a H22A swampped in my Accord. Also did a tranny swap... Dont think that should matter... Car is OBD II ecu and engine is OBD I.... Car is throwing code... Mechanic says its 02 sensor checked the 02 sensor and it is fine nothing wrong with it. But continues to throw code and the only other symptom is car idle' rough when the car is cold and it smells like gas. once the car heats up it still throws the code but idle's fine. Mechanic says injectors is shooting too much fuel. He is kinda stumpped on what is wrong... any help would be appreciated.
Old Mar 28, 2003 | 03:15 AM
93acclude's Avatar
Default Re: H22A O2 Sensor Help (hungy)
How many O2 sensors do you have on the car right now?
[Modified by 93acclude, 12:15 PM 3/28/2003]
Old Mar 28, 2003 | 03:52 AM
KTeller8's Avatar
did the conversion harness right??
[Modified by KTeller8, 2:21 AM 3/30/2003]
Old Mar 28, 2003 | 07:11 AM
hungy's Avatar
I am pretty sure I have two 02 sensors. As for the wirring... we use the piggy back it had the same result then my mechanic wired it by hand one by one. Im pretty sure its not the wirrign... piggy back and his hand wirring had the same result. He pulled the harness to check it as well. He thinks the car idleing hard when it is cold is due to the car being too rich when it is cold. He thinks its some how connect to the 02 sensor light. Any other ideas>? Really appreciate the help guys
[Modified by hungy, 4:15 PM 3/28/2003]
[Modified by hungy, 6:28 PM 3/28/2003]
Old Mar 28, 2003 | 08:23 AM
h22accordvtec's Avatar
OBD1 only uses 1 O2 sensor. OBD2 uses 2.. 1 before cat 1 after
Old Mar 28, 2003 | 08:29 AM
Luisito825's Avatar
im not 100% sure if this applys to you since you went OBDII >OBDI. but on OBDI accords you have to switch the heater o2 pin with the EGR pin. A6 and A11 i think... disconnect the hose that goes from the solenoid to the egr...maybe your idle wont be so ruff.
Old Mar 28, 2003 | 09:37 AM
hungy's Avatar
Default Re: H22A O2 Sensor Help (h22accordvtec)
Just spoke to the mechanic... he said that its not the idling i have problem... Turns out only one of my 02 sensor is hooked up. It turns out that it is not an idling problem rather he said when the car is cold... the car has hesitation when you give it gas.... it does idle fine... just when you give it gas when the car is cold... it hesitates but once it warms up its fine.
[Modified by hungy, 6:51 PM 3/28/2003]
Old Mar 28, 2003 | 09:45 AM
Of course. the ECU doesnt know what to do with response from the other sensor.
Old Mar 29, 2003 | 10:31 PM
hungy's Avatar
bump
No_Limits_Accord
Jul 9, 2008 06:44 PM
crx1racing
May 31, 2005 06:11 PM
hungy
Mar 30, 2003 08:30 AM
