fyi, for 550cc injectors you can use rx7 injectors with corolla clips!
Old Mar 27, 2003 | 09:19 PM
Mr. Softee's Avatar
Default fyi, for 550cc injectors you can use rx7 injectors with corolla clips!
if this has not been posted before I will get more info, just trying to prevent a repost
Old Mar 28, 2003 | 04:00 AM
TurbodCX's Avatar
Default Re: fyi, for 550cc injectors you can use rx7 injectors with corolla clips! (94goldjungsr)
FYI you dont even need the clips, i am using my stock honda clips, i just cut the little tabs off, very simple to do,and i had to do no wireing this way.
HTH
Brian
Old Mar 28, 2003 | 05:00 AM
M.A.R.C.'s Avatar
Default Re: fyi, for 550cc injectors you can use rx7 injectors with corolla clips! (TurbodCX)
i thought cuttin the tabs off only worked on obd1 clips?
Old Mar 28, 2003 | 05:25 AM
Smashback's Avatar
Default Re: fyi, for 550cc injectors you can use rx7 injectors with corolla clips! (CivicRyda2k)
looks like he is obd1
Old Mar 28, 2003 | 05:45 AM
TurbodCX's Avatar
Default Re: fyi, for 550cc injectors you can use rx7 injectors with corolla clips! (Hatchblack)
Ooooopss, sorry bro, yeah i am OBD1 i wasnt thinking about you being OBD2
Brian
Old Mar 28, 2003 | 06:00 AM
Bottoz's Avatar
Yes, you can use 89-91 RX-7 550cc injectors and 90 Corolla clips. I did the research and posted the results. Here's what I found:
Ok, Heres the deal. I got the 89-91 rx-7 550cc Turbo injectors. I searched everywhere trying to find clips...Napa, Autozone, Checker, even the Mazda dealer. The Dealer would only give me the whole fuel harness...so off to the junkyard I went. No RX-7's at any Junkyard here....so I thought maybe some other model Mazdas had the correct clips. Well, all the snow covered the cars, so I couldnt tell what was what. After about 10 mins in the Junkyard, I found a 1990 Corolla...PERFECT FIT...but the clips were chipped and scrached. So, I found another Corolla with clips in gread condition. Cut then off and paid 5 buck for all four.
The RX-7 injectors are a little fatter than the stock 240cc's, so the rubber ring at the end stretched a little when we put them in. Wiring was pretty easy. The Yellow-black on the Corolla clips goes to the Yellow of the Honda harness. The Black-brown of the Corola clip goes to the varied color of the Honda harness. Also, when putting in the injectors, leave the Rubber Ring in the head....insert the injectors to the rail, and tighten down the rail. The force of the rail will seat the injectors into the head.
So, heres what you need for 89-91 RX-7 550cc Injectors to work in your VAFC/SAFC:
4 89-91 RX-7 550cc (denso PN# 195500-2020)
4 Clips from a 90 Toyota Corolla
Thats it, they are saturated (High Impeadance), no resistor box needed.
My VAFC settings are:
1000rpm -25%
2000rpm -35%
3000rpm - 8000rpm -45%.
***EDIT*** USE YOUR OWN V/S-AFC SETTINGS, IM NOW USING AEM EMS***EDIT***
Now for the Pics very HIGH DETAIL 1600x1200.
550cc Injectors and Clips
240cc next to 550cc
550cc, Corolla Clip, 240cc
Try it if ya like!
Bottoz
[Modified by Bottoz, 8:01 AM 3/28/2003]
[Modified by Bottoz, 8:02 AM 3/28/2003]
Old Mar 28, 2003 | 07:20 AM
Mr. Softee's Avatar
Default Re: fyi, for 550cc injectors you can use rx7 injectors with corolla clips! (Bottoz)
Awesome
Old Mar 28, 2003 | 09:11 AM
LS-hatch's Avatar
can the smc+ handle these?
Old Mar 28, 2003 | 10:01 AM
chidoks's Avatar
did u have to use a resistor box?? how many injectors did the rx7 come with?
Old Mar 28, 2003 | 11:51 AM
94TealGSR's Avatar
Default Re: fyi, for 550cc injectors you can use rx7 injectors with corolla clips! (chidoks)
No resistors/resistorbox needed. Read the whole thing next time.
csmith21
Mar 12, 2013 01:43 AM
RTW DC2R
Jul 16, 2006 09:27 AM
EJ8 GSR-T
Apr 26, 2006 06:33 PM
lanojp1
Aug 26, 2004 07:40 PM
