Aftermarket Mounts for D series...
Old Mar 27, 2003 | 08:40 PM
SloCivicHMM's Avatar
Default Aftermarket Mounts for D series...
Hasport makes b series mounts.....so does place racing etc etc..
Any one know where I can get billet or solid after market mounts for my d series motor in my Eg hatch...thanks..need soon as possible car is down due to 3 broken mounts...thanks again..
Old Mar 27, 2003 | 08:54 PM
Spade's Avatar
Default Re: Aftermarket Mounts for D series... (SlowCivicHmm)
I don't remember the site however, there is a performance online shop that sells them.
Hasport and Place racing both make mounts for the D series engines.
But not full kits just specific mounts. They are also 150 each.
I will see if I can find the place that sells the cheap mounts that are polyurethane and cost about 65 each.
It was on H-T so a lot of searching could help you.
Old Mar 28, 2003 | 07:13 AM
Default Re: Aftermarket Mounts for D series... (Spade)
thanks bro...
I need the 2 lower mounts... http://www.jimfab.com makes just the lower mounts for 65 plus shippiing.....
but I also broke the top 2 mounts....lol
Old Mar 28, 2003 | 07:17 AM
Old Mar 28, 2003 | 08:39 AM
turbod16y7vtec's Avatar
how did you do this?
Old Mar 28, 2003 | 08:58 AM
Silver Civic OH's Avatar
Default Re: Aftermarket Mounts for D series... (turbod16y7vtec)
No metter how many times you warn people they still manage to jack the car up using the oil pan.
Just playing.
Old Mar 28, 2003 | 11:44 AM
falken azenis.......enough said.....hahaha.....good *** grip...and they are the stock mounts from 92 its time to lay them to rest uknow.....
Old Mar 29, 2003 | 08:22 PM
Spade's Avatar
Well it was Jimfab.com
Did you find the tranny and upper driver side mount from Hasport?
Unfortunatly they are about 150 each.
Old Apr 3, 2003 | 12:11 PM
jim fab doesn't make the upper mounts....
I have a d series.....will the hasport mounts work??
I was told 94-95 ex block mount will let me use teh GSR upper mount...so I guess I'm going to try that.....150 I know ouch!!!
Old Apr 3, 2003 | 02:24 PM
nsxmatt's Avatar
Yes, the 94-95 SOHC VTEC motors use the same upper mount as the teg and the hasport will work then. Just change out the block mounted mount (under the timing cover) and use the hasport upper. The 92-93's VTEC's and 92-95 DX/CX's use the offset drivers side upper which is the one I assume you have. My b16 uses the odd offset one so i'm stuck on mounts like you are
minspd
Dec 12, 2014 08:07 AM
midwestdan
Aug 15, 2011 08:56 PM
92egboost
Jul 18, 2008 07:02 AM
black0hatch
May 31, 2008 05:01 AM
jdmcivicferio
Sep 24, 2003 03:08 AM
