Fabbed heat sheild for intake today.....tech questions
Old Mar 27, 2003 | 06:49 PM
PotatoePAPA's Avatar
Default Fabbed heat sheild for intake today.....tech questions
It was fabbed out of aluminum sheet metal. (its not quite finished yet) My question is.. is this going to sheild the heat or absorb it and surround the filter with hot air? My question might be vague, but if anyone can answer it, its appreciated.
Old Mar 27, 2003 | 06:52 PM
Spade's Avatar
Default Re: Fabbed heat sheild for intake today.....tech questions (EG CoUpe)
It depends on what it's attached to. I would actually get header wrap instead. That's one of the biggest issues to address first.
Old Mar 27, 2003 | 06:56 PM
Default Re: Fabbed heat sheild for intake today.....tech questions (Spade)
This was more of an Autoshop boredom project. But its a short ram and the shield is directly behind the filter. I also agree with the header wrap. lemme try n snag some pics.
Old Mar 27, 2003 | 07:01 PM
Old Mar 27, 2003 | 07:04 PM
gamby's Avatar
IT will surround the filter w/ hot air once it heats up. If the inner surface of the sheild is hot to the touch, then the sheild is useless. When I ran this setup, I lined my shield on the inside w/ Thermotec cool-it mat. It worked well.
After all my experiments, I sold out and got an AEM CAI. The dyno proved that it was the best setup.
Check the link in my sig and go under 'modifications' for the stuff I tried in the past.
Old Mar 27, 2003 | 07:14 PM
kommon_sense's Avatar
Default Re: Fabbed heat sheild for intake today.....tech questions (gamby)
aluminum will shield the intake from the hot engine bay air until it gets heat soaked and will them warm up the intake air as well. I would recommend spraying the outside with ceramic high temp paint and get some sort of liner on the inside. That should do the trick nicely.
Old Mar 27, 2003 | 07:17 PM
92civicsi's Avatar
Old Mar 27, 2003 | 07:34 PM
Default Re: Fabbed heat sheild for intake today.....tech questions (92civicsi)
why didnt my pics work?
Thanks for the help guys
[Modified by EG CoUpe, 8:34 PM 3/27/2003]
Old Mar 27, 2003 | 07:40 PM
92CIVICCX's Avatar
exaclty what he said.. or it will just act like an oven....i would altually cover the whole area(box it in).. use thin guage aluminumand bend it dont weld it
92civicsi's Avatar
you had a period "." after jpg so i just took it out
Old Mar 27, 2003 | 07:43 PM
Default Re: Fabbed heat sheild for intake today.....tech questions (92CIVICCX)
I got the feeling it was just an oven. I am planning to box it in, but I just ran out of time today.
Looks like I got some tips to cool off my home made oven. Thanks!
Dutch ovens....for cars. muhahahaha. im funny
xPRIMO
Mar 11, 2012 11:05 PM
Kevon
Nov 2, 2007 09:51 PM
AzntstyleZ
Jun 12, 2003 04:17 AM
passinUby
Nov 18, 2002 09:10 AM
