Grind in Tranny...
Wassup guys? Well i have a grind going into 3rd gear. I have a 94 b18b that's pretty much stock cept intake exhaust, ITR clutch and flywheel.
I was wondering what you guys think i should do? Just replace with another ls tranny or go with a b16 or gsr tranny. Would i just be better off with a b16 tranny? By the way it's hydro not cable.
And if anyone would want my ls tranny let me know. The grind is not bad, just when shifting fast, otherwise fine when driving normally.
If you get the Si tranny the gears will be closer. It helps keep it in VTEC when you shift, but seeing as you have an LS, VTEC is not an issue. If the grind isn't too bad and you don't mind doing tranny work, you might want to fix it yourself.
its just a synchro dude, nothing to get rid of the tranny for
sorry for bringing this up from the dead.
The grind in my 3rd has gotten worse, im going to put some tranny fluid in to ease the grind but this summer i'd like to get a new tranny. I would like to go with a b16 and add the ls 5th gear, i was wondering if that is hard to do because in the future i'd like to go turbo.
I'm not tryin to create another "which is better for turbo tranny" but i would like to know which i'd be better off with. I have a b18b if you haven't picked up on it yet.
Thanks guys.
John
Thanks guys.
John
Yeah the B16 would be great upgrade. If you want to get one let me know Email drevinder@hotmail.com.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nY's FiNeSt »</TD></TR><TR><TD CLASS="quote"><BLOCKQUOTE>quote:<HR>ju st have someone replace the syncros...its no big deal
<HR></BLOCKQUOTE>
How much would the syncros cost ?</TD></TR></TABLE>i would like to know that too! can anyone answer this question?
<HR></BLOCKQUOTE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris y0! »</TD></TR><TR><TD CLASS="quote">its just a synchro dude, nothing to get rid of the tranny for</TD></TR></TABLE>
I replaced the Snycros in my old D15b7 and it was some where around 400 $ (with a new clutch)\
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IEATLINT »</TD></TR><TR><TD CLASS="quote">im not quite sure how much they cost (sorry) but i know they're relitively inexpensive. just call a local shop and ask</TD></TR></TABLE>
Synchros are actually very expensive! Expect to pay around 150-200 for 3rd into 4th as they come in sets. You might just be better off with an entirely new trans, rebuilding can potentially cost as much as a used one...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nY's FiNeSt »</TD></TR><TR><TD CLASS="quote"> Well i have a grind going into 3rd gear. </TD></TR></TABLE>
I have that same problem, like you said only when shifting fast. some fool on here told me to keep double cluthN it and it should go away... bad advice or good advice ?? honda makes good engines but shitty trannies imo
Double clutching will not heal a bad synchro. It might serve a purpose in allowing the trans to slow to a more accepting RPM, but this is only a band-aid to the problem...
Might want to try some GM Syncromesh. If that doesn't do it and this is your only car, just replace the whole tranny, unless you can afford the down time of fixing your current one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Miles85916 »</TD></TR><TR><TD CLASS="quote">go with the B16 tranny way much better then the GSR</TD></TR></TABLE>
about how much does a hydro b16 tranny go for? around 500-600 ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jolt-tsp »</TD></TR><TR><TD CLASS="quote">Might want to try some GM Syncromesh. If that doesn't do it and this is your only car, just replace the whole tranny, unless you can afford the down time of fixing your current one. </TD></TR></TABLE>
GM synchos? as in General Motor's syncho's in a honda tranny? does that shiet work? are they better?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nY's FiNeSt »</TD></TR><TR><TD CLASS="quote">yeah i'm just going to get a gsr tranny, shorter ratio than my sucky ls
</TD></TR></TABLE>b16 would be better!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek4 fa sho »</TD></TR><TR><TD CLASS="quote">b16 would be better!!!
how so? i heard people like the gsr tranny on their ls motors better than the b16
</TD></TR></TABLE>how so? i heard people like the gsr tranny on their ls motors better than the b16
