What is vapor lock?
Old Jun 17, 2001 | 02:13 AM
typer694's Avatar
New User
Default What is vapor lock?
What is vapor lock, how is it caused, and what are the symptoms of vapor lock. According to my local honda technician this is what happened to my car this friday. I won't go into details as of yet because i want to see if any one describes the same symptoms that happened to my car, and if my mechanic was right or not. Personally i have never heard of this before. All i can say is it is not a good thing if this is what really happened. Thank you!
Old Jun 17, 2001 | 02:34 AM
Hybrid ctr's Avatar
Default Re: What is vapor lock? (typer694)
you mean hydro lock, as in your engine sucked in water
Old Jun 17, 2001 | 02:56 AM
typer694's Avatar
New User
Default Re: What is vapor lock? (Hybrid ctr)
No. I know what hydro lock is and i saw it happen to my friends LS motor. I am talking about something to do with the fuel or fuel system called vapor lock.
Old Jun 17, 2001 | 03:15 AM
TurboType-R's Avatar
New User
vapor lock, is when the fuel atomizes from heat before it gets into the cylinders causing the car to die, it usually happens in carborated cars more than fuel injected
Old Jun 17, 2001 | 03:18 AM
Stage Five ITR's Avatar
Default Re: What is vapor lock? (TurboType-R)
"vapour lock is when the heat of the engine vapourises the fuel in
the fuel line. this usually(?) happens after you turn the engine off and
stop the fuel flow. it doesn't seem likely to me to happen on a bike with
short fuel lines (i.e. straight down from tank to carbs). i used to get
the problem on an old car where the fuel line ran around 75% of the engine
before getting to the carb.
what i have had happen to me on a bike (and i've heard about often enough)
is vacuum lock (? for want of a better term) where a lack of air getting
into the tank eventually causes enough of a vacuum to stop fuel flowing
out the bottom. if you open the tank after you've stopped and you hear
an inrush of air this could indicate this problem. my long term solution
was to 'fix' the cap so that more air could get in. "
...just something that I found on the net...like that?
Old Jun 17, 2001 | 03:19 AM
Default Re: What is vapor lock? (Stage Five ITR)
"Another possibility is that the fuel system is not replenishing the fuel at
the same, or greater, rate that the engine is using it."
...also this : )
Old Jun 17, 2001 | 04:42 AM
typer694's Avatar
New User
Thank you, that is closer to what i was looking for. That is pretty much what my mechanic told me. Could this hapen due to getting some bad fuel? Say fuel with water in it?
[Modified by typer694, 5:44 AM 6/17/2001]
Old Jun 17, 2001 | 05:21 PM
typer694's Avatar
New User
Any one???
Old Jun 17, 2001 | 06:35 PM
Big Phat R's Avatar
If you have water in your lines - use methyl hydrate. Usually water in the lines is not a big problem unless it's freezing outside.
If you have vapour lock try changing your gas cap to a new one.
Old Jun 17, 2001 | 10:40 PM
typer694's Avatar
New User
Default Re: What is vapor lock? (Big Phat R)
Big Phat R. Thanks. I am going to swing by the dealer tommorow and get a new gas cap and fuel filter and see if that helps.
afnan
Apr 3, 2014 02:08 PM
dropkneeyoungin
Oct 10, 2009 07:55 PM
EK22snatch
Aug 23, 2004 06:31 PM
eg6_lsi
Mar 25, 2004 10:29 PM
conesmasher
Jul 29, 2003 09:18 AM
