Where is the Map sensor on the CRX Si motor?
Old Mar 27, 2003 | 04:24 PM
Ri5e's Avatar
Default Where is the Map sensor on the CRX Si motor?
I can't seem to locate the Map sensor for the CRX Si motor. Gonna trick it from seeing boost...
Old Mar 27, 2003 | 04:44 PM
RuffRhyno's Avatar
Default Re: Where is the Map sensor on the CRX Si motor? (4 Stroke)
It's not mounted on the throttle body like the new Hondas, it's actually mounted on the firewall by the intake manifold but a little more towards the passenger side. It's got vacuum lines running out of it, etc..
HondaPartsHero's Avatar
Technical Hero
its on the firewall, has a three wire plug going to it and a vacuum line.
Old Mar 27, 2003 | 05:04 PM
Ri5e's Avatar
Default Re: Where is the Map sensor on the CRX Si motor? (yebabee)
hmm..there are like..3 of them, haha. which one? kinda dark outside...
Old Mar 27, 2003 | 06:18 PM
BTLFED's Avatar
If you are looking at the firewall from the front of the car, there is a piece sitting on the firewall that has either one or two vacuum canisters (depending on the year) and a piece on the left of it (or them) that is screwed upside down next to them with a plug and a vacuum line hooked up to it. TaDa! Map sensor.
importgod21682
Oct 9, 2006 11:23 AM
90b20vteckidd
17
Sep 27, 2006 06:03 PM
orangeracer
11
Mar 19, 2006 05:46 AM
spidermancivic
Aug 25, 2005 09:45 AM
Ri5e
Sep 21, 2004 02:16 PM
